Could not move recorded media to destination
Server Version#: 1.21.3.4046 - Ubuntu 20.04
Tuner Make/Model: Xteve
Guide/Lineup name: XEPG
Using XMLTV?: Yes
Channel number/Name:
Hello. I have PMS running on Ubuntu 20.04. I have set up Xteve to use for Live TV/DVR. I have a ReadyNas 214 receiving all the recordings. I have the dshared folder in the ReadyNas 214 mounted. I have set my PMS-linux machine as Plex as a user. The shared folder - user Plex has administrator privileges. The Live TV DVR, looks like content is recording but then after it is finished I get :Could not move recorded media to destination. I saw prior posts in the forum and some users suggested a clean install of PMS. I did that, and that did not work. Please help.
Here are a few lines from my logs:
Feb 16, 2021 23:44:41.415 [0x7fbb44ff9700] DEBUG - [Grabber/47fe8fef261780fdc75a9c4b5ef285ad30a7c702] Subscription: Failed to resolve subscription for movie ‘guid: tv.plex.xmltv://movie/Dark%20Water ratingKey: tv%2Eplex%2Exmltv%3A%2F%2Fmovie%2FDark%2520Water thumb: http://apk.eternaltv.net/icons/cinemax-thrillermax.png title: Dark Water type: 1’ to library item
Feb 16, 2021 23:44:41.415 [0x7fbb44ff9700] DEBUG - [Grabber/47fe8fef261780fdc75a9c4b5ef285ad30a7c702] Assimilator: Postprocessing, we’re going to put Dark Water in /nas/movies/Dark Water/Dark Water.ts
Feb 16, 2021 23:44:41.415 [0x7fbb6a7fc700] DEBUG - [LibraryTimeline] Scanner activity on section 3: 20400 added, 0 deleted
Feb 16, 2021 23:44:41.416 [0x7fbb44ff9700] ERROR - [Grabber/47fe8fef261780fdc75a9c4b5ef285ad30a7c702] Error creating directory “/nas/movies/Dark Water”: Permission denied
Feb 16, 2021 23:44:41.416 [0x7fbb44ff9700] ERROR - [Grabber/47fe8fef261780fdc75a9c4b5ef285ad30a7c702] Assimilator: Could not create directory at path /nas/movies/Dark Water
Feb 16, 2021 23:44:41.416 [0x7fbb44ff9700] DEBUG - [Grabber/47fe8fef261780fdc75a9c4b5ef285ad30a7c702] Grabber: Operation for ‘Dark Water’ on channel 1005 completed with status error (Could not move recorded media to destination)
Feb 16, 2021 23:44:41.417 [0x7fbb44ff9700] DEBUG - [Grabber/47fe8fef261780fdc75a9c4b5ef285ad30a7c702] Activity: Ended activity 4851da74-401f-476e-b45f-a6b55689ca04.
Feb 16, 2021 23:44:41.417 [0x7fbb457fa700] DEBUG - [Grabber/47fe8fef261780fdc75a9c4b5ef285ad30a7c702] Activity: Ended activity abf77809-5f0c-406b-93a5-be1c8932729e.
Feb 16, 2021 23:44:41.418 [0x7fbb5b7fe700] DEBUG - HTTP requesting GET http://192.168.50.132:34400/discover.json
Feb 16, 2021 23:44:41.419 [0x7fbb5b7fe700] DEBUG - HTTP 200 response from GET http://192.168.50.132:34400/discover.json
Feb 16, 2021 23:44:41.419 [0x7fbb5b7fe700] DEBUG - HTTP requesting GET http://192.168.50.132:34400/lineup_status.json
Feb 16, 2021 23:44:41.420 [0x7fbb5b7fe700] DEBUG - HTTP 200 response from GET http://192.168.50.132:34400/lineup_status.json
Is it a problem with permissions? Plex has rwx - privileges
I had a similar problem on a Synology NAS (where you install the package and it run as a container using as user ‘plex’). My ultimate issue was a permission problem–specifically with access control lists (ACLs) that appear to be in use.
When I ran commands (ls -l) on the Synlogy server to check the permissions on the directory to which the files were to be moved, I noted a ‘+’ character–which is used to signify that ACLs have been applied. If you add the ‘-e’ flag to ‘ls’, it will show the ACLs
sh-4.3# ls -el  '/volume1/Media/TV Shows'
total 0
drwx------+ 1 plex users  84 Feb 14 09:00 Some Show (2007)
	 [0] user:plex:allow:rwxpdDaARWcCo:fd-- (level: 0)
	 [1] user:plex:allow:rwxp--aARWc--:fd-- (level: 1)
	 [2] group:administrators:allow:rwxpdDaARWc--:fd-- (level: 2)
	 [3] user:plex:allow:r-x---a-R-c--:fd-- (level: 2)
Noting the absence of a ‘w’ (write) permission in the last ACL, I ran the following command as root to add write permission for plex in all folders (and files) in the destination directory (and it’s subdirectories):
sh-4.3# chmod -R +a user:plex:allow:w /volume1/Media/
Following that command, the permissions looked like this and subsequent recordings were moved to the proper location (and available via Plex clients):
total 0
	 [3] user:plex:allow:rwx---a-R-c--:fd-- (level: 2)
I’ve not checked if old recordings that failed to move were retroactively relocated (though I could do that manually), but at least it’s working. Hopefully this helps you or others track things down–good luck!
In my case Plex is able to create the destination folder (e.g. <mytvlibraryfolder>/My TV Show (2019)/Season 01/), but log shows Grabber error and the .grab folder is empty.
The frustrating part: it was working fine before.
The relevant settings / details:
  • PMS 1.22.2.4282 on Mac
  • 30GB free storage
  • Enigma2 based STB running HRTunerProxy - modified to serve transcoded stream (port 8002) instead of hi-res stream (port 8001)
  • Viewing live streams works fine
  • no postprocessing script
  • Live TV & DVR > DVR settings > detect commercials > disabled
  • Live TV & DVR > device settings > convert video while recording > off
I stopped working I think after I was tweaking a couple of the options (transcoded/hi-res stream, detect commercials, convert video while recording). I did reset them to the original values and I removed + added the DVR device, and restarted all devices (DVR + PMS). But no effect.
Log shows Grabber error for the file that was recorded:
Plex Media Server.log:Apr 21, 2021 10:30:00.406 [0x70000cde0000]
ERROR - [Grabber/12ce6dfcd1a...6ab4567a9f961c]
Failed to inspect file:
Could not parse <mytvlibraryfolder>/.grab/12ce6dfcd1a...6ab4567a9f961c-76ac01f65dcb...02209ba2635/My TV Show (2019) - S01E22 - my title.ts (error=-2): No such file or directory
The mentioned .grab folder is empty.
Permissions for the folders in <mytvlibraryfolder>:
drwxr-xr-x myuser staff 64 B Wed Apr 21 10:30:00 2021 .grab
drwxr-xr-x myuser staff 96 B Wed Apr 21 10:30:00 2021 My TV Show (2019)
drwxr-xr-x myuser staff 64 B Wed Apr 21 10:30:00 2021 My TV Show (2019)/Season 01
Maybe not related, but also getting -every 5 minutes- for 34 items:
Apr 21, 2021 10:45:44.372 [0x70000b968000] ERROR - LPE: unknown item 1234.
Apr 21, 2021 10:45:44.373 [0x70000b968000] ERROR - Sync: failed to generate query for path library://648f0842-4302-...-4c4dc5cec9f0/item/%2Flibrary%2Fmetadata%2F1234 in sync item 12345678
Apr 21, 2021 10:45:44.373 [0x70000b968000] WARN - Sync: sync item 12345678 has an empty sync set query, assuming sync item is no longer valid
Currently using version 1.23.1.4602
The console shows a warning when the recording is completed:
Assimilator: Could not compute a final destination, not postprocessing
Also seeing in log (multiple times, before and after recordings, not sure if related):
SQLITE3:0x10...40, 28, double-quoted string literal: "2021-06-04 12:00:00"
Problem went away after downloading + installing the software again.
Thank you wivaku for your responses. I have plex running off of my original Windows PC, for the time being. I will attempt your suggestions on my Ubuntu machine.
