Could not tune channel. Please check your tuner or antenna
This is a screencast of the service crashing and recovering:
Screencast
Adding to this as I have never had it running properly. Yes, there were times when the tuner actually started and showed a stream only to fail with the “could not tune channel” message when switching to the next channel. However this was a lucky occurrence and my WinTV-dualHD has been idle since I bought it 2 years back to use with Plex.
Here is my system data in case it helps:
  • OS: Win Server 2016 running in a VM
  • Plex: Version 1.24.4.5081
  • Tuner: WinTV-dualHD
  • XML TV used for guide
  • WinTv8 SW uninstalled from the host as I saw that this could case issues
Live TV & DVR Configuration: works fine, all 6 channels we have here are found.
Signal strength could be better but it shows up
Starting a live stream from Windows 10 app or web browser will result in a long loading cycle followed by:
While the channel tries to load the Plex DVR settings show that one runner channel is engaged (light changes).
  • Idle mode
  • While trying to access the channel
Log files extracted from the server:
Plex Tuner Service.1.zip (22.8 KB)
Hope a solution can be found.
Would need all the server logs and not just the Plex Tuner Service logs
I have some channels working some not, really annoying Plex Media Server Logs_2021-10-10_18-02-43.zip (749.7 KB)
I am seeing this curl error in the log
Oct 10, 2021 17:40:55.077 [0xb18c0d48] WARN - [Grabber/5fc76c607dc1e8002d48a67f-5fc706077dd72e002d6dd424-68D63D34-AA90-4810-8950-584A82802B3B] HTTP error requesting GET http://192.168.0.152:55555/devices/vbox-4444 (52, Server returned nothing (no headers, no data)). Network appears to be configured for jumbo frames.
Do you have jumbo frames ? What is the MTU size on the network card ? in the router?
Hey
I don’t have jumbo frames enabled and the mtu is 1500
It seems most of the requests /streaming from the vbox are failing
All these failed
Oct 10, 2021 17:36:24.078 [0xb0482d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 17:36:24.079 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10048 is 1 (failure)
Oct 10, 2021 17:36:27.014 [0xb12b3d48] ERROR - [Transcoder] [tcp @ 0xb6b2b780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:36:27.014 [0xb135ed48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1: Connection refused
Oct 10, 2021 17:36:27.016 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10050 is 1 (failure)
Oct 10, 2021 17:36:28.803 [0xb1064d48] ERROR - [Transcoder] [tcp @ 0xb6b68780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:36:28.803 [0xb0e56d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1: Connection refused
Oct 10, 2021 17:36:28.805 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10052 is 1 (failure)
Oct 10, 2021 17:36:31.030 [0xb0526d48] ERROR - [Transcoder] [tcp @ 0xb6aca780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:36:31.031 [0xb135ed48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/10%20Peach: Connection refused
Oct 10, 2021 17:36:31.032 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10054 is 1 (failure)
Oct 10, 2021 17:36:44.296 [0xb0e33d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 17:36:44.298 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10062 is 1 (failure)
Oct 10, 2021 17:36:46.740 [0xb135ed48] ERROR - [Transcoder] [tcp @ 0xb6b01780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:36:46.741 [0xb0e33d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: Connection refused
Oct 10, 2021 17:36:46.742 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10064 is 1 (failure)
Oct 10, 2021 17:37:53.104 [0xb1044d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 17:37:53.106 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10095 is 1 (failure)
Oct 10, 2021 17:38:10.951 [0xb1087d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/Channel%209%20Sydney: End of file
Oct 10, 2021 17:38:10.953 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10101 is 1 (failure)
Oct 10, 2021 17:38:15.061 [0xb1087d48] ERROR - [Transcoder] [tcp @ 0xb6b13780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:38:15.061 [0xb0549d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/10%20BOLD: Connection refused
Oct 10, 2021 17:38:15.062 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10103 is 1 (failure)
Oct 10, 2021 17:38:17.619 [0xb1087d48] ERROR - [Transcoder] [tcp @ 0xb6acc780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:38:17.619 [0xb0549d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/10%20BOLD: Connection refused
Oct 10, 2021 17:38:17.621 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10105 is 1 (failure)
Oct 10, 2021 17:39:11.140 [0xb1087d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 17:39:11.141 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10128 is 1 (failure)
Oct 10, 2021 17:39:13.155 [0xb0549d48] ERROR - [Transcoder] [tcp @ 0xb6b12780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:39:13.155 [0xb1064d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/Channel%209%20Sydney: Connection refused
Oct 10, 2021 17:39:13.157 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10130 is 1 (failure)
Oct 10, 2021 17:39:15.004 [0xb1087d48] ERROR - [Transcoder] [tcp @ 0xb664e480] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:39:15.005 [0xb1064d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/10: Connection refused
Oct 10, 2021 17:39:15.006 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10132 is 1 (failure)
Oct 10, 2021 17:39:16.745 [0xb0549d48] ERROR - [Transcoder] [tcp @ 0xb661f480] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:39:16.745 [0xb1190d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/10: Connection refused
Oct 10, 2021 17:39:16.747 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10134 is 1 (failure)
Oct 10, 2021 17:39:18.384 [0xb1087d48] ERROR - [Transcoder] [tcp @ 0xb6b5b780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:39:18.384 [0xb1064d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1: Connection refused
Oct 10, 2021 17:39:18.386 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10136 is 1 (failure)
Oct 10, 2021 17:39:27.132 [0xb1087d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 17:39:27.136 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10141 is 1 (failure)
Oct 10, 2021 17:39:32.170 [0xb1087d48] ERROR - [Transcoder] [tcp @ 0xb6b4d780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:39:32.171 [0xb1064d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1: Connection refused
Oct 10, 2021 17:39:32.172 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10143 is 1 (failure)
Oct 10, 2021 17:39:34.014 [0xb1064d48] ERROR - [Transcoder] [tcp @ 0xb6b54780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:39:34.015 [0xb0549d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1: Connection refused
Oct 10, 2021 17:39:34.017 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10145 is 1 (failure)
Oct 10, 2021 17:40:29.676 [0xb1087d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 17:40:29.678 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10174 is 1 (failure)
Oct 10, 2021 17:40:46.350 [0xb1190d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7HD%20Sydney: End of file
Oct 10, 2021 17:40:46.351 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10179 is 1 (failure)
Oct 10, 2021 17:40:50.331 [0xb1041d48] ERROR - [Transcoder] [tcp @ 0xb6ade780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:40:50.331 [0xb1190d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7TWO%20Sydney: Connection refused
Oct 10, 2021 17:40:50.333 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10181 is 1 (failure)
Oct 10, 2021 17:40:51.913 [0xb1190d48] ERROR - [Transcoder] [tcp @ 0xb6b12780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:40:51.914 [0xb152dd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7mate%20Sydney: Connection refused
Oct 10, 2021 17:40:51.915 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10183 is 1 (failure)
Oct 10, 2021 17:40:52.968 [0xb1041d48] ERROR - [Transcoder] [tcp @ 0xb6b6b780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:40:52.968 [0xb152dd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7mateHD%20Sydney: Connection refused
Oct 10, 2021 17:40:52.970 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10185 is 1 (failure)
Oct 10, 2021 17:40:55.080 [0xb152dd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7flix%20Sydney: End of file
Oct 10, 2021 17:40:55.084 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10187 is 1 (failure)
Oct 10, 2021 17:40:56.900 [0xb1041d48] ERROR - [Transcoder] [tcp @ 0xb6b63780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:40:56.900 [0xb16bfd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7flix%20Sydney: Connection refused
Oct 10, 2021 17:40:56.902 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10190 is 1 (failure)
Oct 10, 2021 17:40:59.558 [0xb16bfd48] ERROR - [Transcoder] [tcp @ 0xb6b8b780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:40:59.559 [0xb1041d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/9Gem%20Sydney: Connection refused
Oct 10, 2021 17:40:59.560 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10192 is 1 (failure)
Oct 10, 2021 17:41:00.987 [0xb1190d48] ERROR - [Transcoder] [tcp @ 0xb6b27780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:41:00.987 [0xb152dd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/9Go%21%20Sydney: Connection refused
Oct 10, 2021 17:41:00.989 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10194 is 1 (failure)
Oct 10, 2021 17:41:03.113 [0xb16bfd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/9Life%20Sydney: End of file
Oct 10, 2021 17:41:03.124 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10197 is 1 (failure)
Oct 10, 2021 17:41:05.365 [0xb152dd48] ERROR - [Transcoder] [tcp @ 0xb6b83780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:41:05.366 [0xb16bfd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/9Rush%20Sydney: Connection refused
Oct 10, 2021 17:41:05.368 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10199 is 1 (failure)
Oct 10, 2021 17:41:06.851 [0xb152dd48] ERROR - [Transcoder] [tcp @ 0xb6b0c780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:41:06.855 [0xb152dd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/Double%20J: Connection refused
Oct 10, 2021 17:41:06.858 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10201 is 1 (failure)
Oct 10, 2021 17:41:20.015 [0xb16bfd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 17:41:20.017 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10205 is 1 (failure)
Oct 10, 2021 17:41:25.196 [0xb152dd48] ERROR - [Transcoder] [tcp @ 0xb6b9a780] Connection to tcp://192.168.0.152:55555 failed: Connection refused
Oct 10, 2021 17:41:25.196 [0xb16bfd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/Channel%209%20Sydney: Connection refused
Oct 10, 2021 17:41:25.198 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10208 is 1 (failure)
Oct 10, 2021 17:41:34.126 [0xb16bfd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 17:41:34.128 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10210 is 1 (failure)
Oct 10, 2021 17:57:18.421 [0xb13c1d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 17:57:18.423 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10429 is 1 (failure)
Oct 10, 2021 17:59:53.445 [0xb1303d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 17:59:53.449 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10493 is 1 (failure)
Oct 10, 2021 18:01:07.746 [0xb1510d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 18:01:07.748 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10524 is 1 (failure)
Oct 10, 2021 18:01:27.557 [0xb0b12d48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 18:01:27.560 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10548 is 1 (failure)
Oct 10, 2021 18:01:47.806 [0xb0fedd48] ERROR - [Transcoder] http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney: End of file
Oct 10, 2021 18:01:47.808 [0xb3310d48] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 10556 is 1 (failure)
The logs show requests to the vbox are failing e.g. no more data coming in this example
or connection refused in this example
Is this vbox one of the 2 supported models mentioned on Supported DVR Tuners and Antennas | Plex Support ?
Yup I have VBox xti 3442.
Some channels work fine while some through up the errors
All stream fine when not through plex
I would like to look further into the curl error 52’s
You mentioned mtu size is set to 1500
Could you follow the steps here to see if it should be reduced from that
See
Starting with 1462 do this command in command line window
ping 8.8.8.8 -f -l 1462
if ok then add 10
ping 8.8.8.8 -f -l 1472
and continue adding 10 at a time until you get this error
Packet needs to be fragmented but DF set.
and set then mtu size to be the highest number that did not return this
see this for reference Ping Test to determine Optimal MTU Size on Router | Answer | NETGEAR Support
and then try out the tunes and see if we still get error 52 in the logs
e.g.
Oct 10, 2021 17:36:23.968 [0xb1aeed48] DEBUG - [Grabber/5fc76c607dc1e8002d48a67f-5fc70603c8d56d002e06f9b2-68D63D34-AA90-4810-8950-584A82802B3B] HTTP requesting GET http://192.168.0.152:55555/devices/vbox-4444
Oct 10, 2021 17:36:24.083 [0xb1aeed48] ERROR - [Grabber/5fc76c607dc1e8002d48a67f-5fc70603c8d56d002e06f9b2-68D63D34-AA90-4810-8950-584A82802B3B] Error issuing curl_easy_perform(handle): 52
That command throws errors, i dont have a windows machine. Linux or macOS
In that case I cannot help you troubleshooting the problems. I thought everybody had a PC these days
You did have a Macbook a week ago and there was also a linux machine other than the pie showing up on your account
Yeah I don’t have windows
I have macOS and Linux machine, I tried what you said and the command says there’s an error
I have the same VBoxx and i have problems tunning into channels. From what i can figure out it the problem appears to be on the url parsing, i.e.:
I suspect that Plex isn’t parsing correctly the “%20” (Space) special character since the error happens only on the channels that have a “Space” in the name. You can see the same behavior in the other users logs (all the channels with “%20” special character failed tuning in).
ping appears to have different syntax on windows / mac / linux
Windows
ping 8.8.8.8 -f -l 1452
etc
Mac OS
ping -D -s 1452 8.8.8.8
ping -D -s 1462 8.8.8.8
ping -D -s 1472 8.8.8.8
etc
Linux
ping 8.8.8.8 -f -s 1452
ping 8.8.8.8 -f -s 1462
ping 8.8.8.8 -f -s 1472
etc
Thank you very much for the investigation. I arranged to get one of these vbox DVRs to try it. I will like to see the list of channel identifiers returned by the vbox
The logged errors from @nickelslol also had errors for requests not relating to specific channels - eg this
Oct 10, 2021 17:36:24.083 [0xb1aeed48] WARN - [Grabber/5fc76c607dc1e8002d48a67f-5fc70603c8d56d002e06f9b2-68D63D34-AA90-4810-8950-584A82802B3B] HTTP error requesting GET http://192.168.0.152:55555/devices/vbox-4444 (52, Server returned nothing (no headers, no data)). Network appears to be configured for jumbo frames.
This was an error to request http://192.168.0.152:55555/devices/vbox-4444
May be device was not in the right state at the time - because I do see this request succeeding at other times
@nickelslol could you also get me the responses you get back in a browser to these requests - please copy the returned response to text file and attach here
and
http://192.168.0.152:55555/devices/vbox-4444/scanners
It is not consistent - this analysis extract sorted by channel identifier and time
time	Transcoder vbox http request	Outcome
Oct 10, 2021 17:36:35.367	http://192.168.0.152:55555/devices/vbox-4444/media/10
Oct 10, 2021 17:39:14.966	http://192.168.0.152:55555/devices/vbox-4444/media/10	Transcoder failure
Oct 10, 2021 17:39:16.716	http://192.168.0.152:55555/devices/vbox-4444/media/10	Transcoder failure
Oct 10, 2021 17:39:37.169	http://192.168.0.152:55555/devices/vbox-4444/media/10
Oct 10, 2021 18:01:17.535	http://192.168.0.152:55555/devices/vbox-4444/media/10
Oct 10, 2021 17:38:15.021	http://192.168.0.152:55555/devices/vbox-4444/media/10%20BOLD	Transcoder failure
Oct 10, 2021 17:38:17.591	http://192.168.0.152:55555/devices/vbox-4444/media/10%20BOLD	Transcoder failure
Oct 10, 2021 17:57:10.221	http://192.168.0.152:55555/devices/vbox-4444/media/10%20BOLD
Oct 10, 2021 17:36:26.984	http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1	Transcoder failure
Oct 10, 2021 17:36:28.774	http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1	Transcoder failure
Oct 10, 2021 17:36:58.434	http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1
Oct 10, 2021 17:39:18.357	http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1	Transcoder failure
Oct 10, 2021 17:39:20.369	http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1
Oct 10, 2021 17:39:32.138	http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1	Transcoder failure
Oct 10, 2021 17:39:33.975	http://192.168.0.152:55555/devices/vbox-4444/media/10%20HD_1	Transcoder failure
Oct 10, 2021 17:36:31.004	http://192.168.0.152:55555/devices/vbox-4444/media/10%20Peach	Transcoder failure
Oct 10, 2021 17:38:18.980	http://192.168.0.152:55555/devices/vbox-4444/media/10%20Peach
Oct 10, 2021 17:36:23.988	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:36:44.205	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:36:46.708	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:37:53.007	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:39:11.056	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:39:27.038	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:40:29.590	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:41:19.921	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:41:34.030	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:57:18.324	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:59:53.355	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 18:01:07.656	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 18:01:27.468	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 18:01:47.704	http://192.168.0.152:55555/devices/vbox-4444/media/7%20Sydney	Transcoder failure
Oct 10, 2021 17:40:54.289	http://192.168.0.152:55555/devices/vbox-4444/media/7flix%20Sydney	Transcoder failure
Oct 10, 2021 17:40:56.858	http://192.168.0.152:55555/devices/vbox-4444/media/7flix%20Sydney	Transcoder failure
Oct 10, 2021 17:40:46.255	http://192.168.0.152:55555/devices/vbox-4444/media/7HD%20Sydney	Transcoder failure
Oct 10, 2021 17:40:51.850	http://192.168.0.152:55555/devices/vbox-4444/media/7mate%20Sydney	Transcoder failure
Oct 10, 2021 17:40:52.920	http://192.168.0.152:55555/devices/vbox-4444/media/7mateHD%20Sydney	Transcoder failure
Oct 10, 2021 17:40:50.284	http://192.168.0.152:55555/devices/vbox-4444/media/7TWO%20Sydney	Transcoder failure
Oct 10, 2021 17:40:59.527	http://192.168.0.152:55555/devices/vbox-4444/media/9Gem%20Sydney	Transcoder failure
Oct 10, 2021 17:41:00.953	http://192.168.0.152:55555/devices/vbox-4444/media/9Go%21%20Sydney	Transcoder failure
Oct 10, 2021 17:41:02.379	http://192.168.0.152:55555/devices/vbox-4444/media/9Life%20Sydney	Transcoder failure
Oct 10, 2021 17:41:05.321	http://192.168.0.152:55555/devices/vbox-4444/media/9Rush%20Sydney	Transcoder failure
Oct 10, 2021 17:38:37.288	http://192.168.0.152:55555/devices/vbox-4444/media/ABC%20TV
Oct 10, 2021 17:38:10.713	http://192.168.0.152:55555/devices/vbox-4444/media/Channel%209%20Sydney	Transcoder failure
Oct 10, 2021 17:39:13.115	http://192.168.0.152:55555/devices/vbox-4444/media/Channel%209%20Sydney	Transcoder failure
Oct 10, 2021 17:41:25.168	http://192.168.0.152:55555/devices/vbox-4444/media/Channel%209%20Sydney	Transcoder failure
Oct 10, 2021 17:41:06.797	http://192.168.0.152:55555/devices/vbox-4444/media/Double%20J	Transcoder failure
Oct 10, 2021 17:39:01.585	http://192.168.0.152:55555/devices/vbox-4444/media/SBS%20ONE
You can some of the requests with the %20 did not fail.
Thanks, apparently i loose all packets when pinging outside my network with that, i have internet connectivity
Here’s the files
scanners.txt (272 Bytes)
4444.txt (516 Bytes)
OK - instead of the -f argument, try the -i interval (1 second intervals)
 ping 1.1.1.1 -i 1 -c 4 -s 1452
 ping 1.1.1.1 -i 1 -c 4 -s 1462
 ping 1.1.1.1 -i 1 -c 4 -s 1472
 ping 1.1.1.1 -i 1 -c 4 -s 1482
could you also try this request - it should list the channels
http://192.168.0.152:55555/devices/vbox-4444/channels
The logs I analyzed and summarized outcomes here Could not tune channel. Please check your tuner or antenna - #265 by sa2000 do not show consistency
eg this channel “10 HD_1” appeared to tune sometimes and fail at other times
