Could not tune channel. Please check your tuner or antenna
Thank you for getting back, is there anyhting that I can do to mitigate this issue in the meantime?
Please see attached. Error occurred at approx 3p on web interface on M1 Mac mini and on Plex app on ATV 4k3 with HD HOMERUN Connect Duo
Thanks in advance for your assistance.
Plex Media Server Logs_2021-12-25_15-06-32.zip (4.2 MB)
Interesting side-not. The Guide stopped loading 12/26 and I was able to watch shows using the ā€œWhat’s Onā€ section
On the web version on Mac, the tv session keeps ending. ā€œThe Live Playback has endedā€. No issue on the Apple TV. Logs attached.
Plex Media Server Logs_2021-12-28_10-27-01.zip (3.8 MB)
For a few weeks was getting ā€œCould not tune channelā€¦ā€ and ā€œAn unexpected error occurredā€ when trying to tune some channels (TVHeadend on RaspberryPi with Antennas emulating HDHomerun). There was no apparent consistency in which channels would or wouldn’t tune - it seemed random. Re-installed PMS (OSX 10.13.6 on Mac Mini), Raspbian Buster on Pi 4B+, TVHeadend and Antennas with no luck. Reset network - no luck. What DID work was removing PMS for Mac 1.25.2.5319 and rolling back to 1.24.5173. Now all fine again. Have disabled automatic updates on the server until Plex sort this out.
…Check your tuner or antenna
same at every client on every channel (Android,Windows,Ubuntu,Web are tested)
Plex knowing my Vu+ 4K Duo - VTI 15 - HRTunerProxy
knowing Channellist
knowing EPG
but at least wont play -
thx for help
Hi all, i just bought VBox Xti-3442 TV gateway a have a similar issue to this a guess. I am from czech republic and want to watch czech live TV channel. We have special character in channel names. I tried to write on VBox support, but they wanted to know if i ask you (plex support). So here i am asking for help.
Only some channel works. I belive they are those withc doestn contains special characters or spaces. For example Xmltv file:
These channel doesnt work (even if a change display name into somethin withnout special chars:
<channel id="www.CT%20sport%20HD%20T2.co.un">
<display-name>CT sport HD T2</display-name>
<display-name>TV</display-name>
<display-name>T2-CZE-20cb21110112</display-name>
<display-name>Free</display-name>
<display-name>1298</display-name>
<icon src="http://192.168.0.10:55555/images/tv_icon.jpg"/>
<url src="http://192.168.0.10:55555/CT%20sport%20HD%20T2"/>
</channel>
<channel id="www.CT%203%20HD%20T2.co.un">
<display-name>CT 3 HD T2</display-name>
<display-name>T2-CZE-20cb21110116</display-name>
<display-name>1302</display-name>
<url src="http://192.168.0.10:55555/CT%203%20HD%20T2"/>
</channel>
<channel id="www.%20Nova%20Action.co.un">
<display-name> Nova Action</display-name>
<display-name>T2-CZE-20cb04010203</display-name>
<display-name>1539</display-name>
<url src="http://192.168.0.10:55555/%20Nova%20Action"/>
</channel>
But this works:
<channel id="www.Prima.co.un">
<display-name>Prima</display-name>
<display-name>T2-CZE-20cbf2060312</display-name>
<display-name>1810</display-name>
<url src="http://192.168.0.10:55555/Prima"/>
</channel>
Can you help me with that please. Is there any workaround for it?
This is already a known issue and Plex is working on it.
Thanks… Can be a workaround xTeve? Or we need to wait until Plex will fix it.
Thanks… …
Don’t hold your breath. It’s been like this for years with no resolve.
so i did a new setup of Vu+ and plexserver… (dont wanna do it - but no help …)
and something is going right - everythingś fine with Vu+ Duo 4k - VTI15 - HRTunerProxy :sweat:
after 3 month’s - happy streamin’ with LiveDVR again
… and Plex - after paying Plexpass and beeing member since years
→ … no star support :scream:
Having this issue and can only change channels a few times before I get the error. I’m using Ubuntu 20.04.
I used the same USB tuner on a Raspberry Pi 3B and never noticed this issue. Decided to buy an Intel based computer (also bought Plex Pass) for better performance and now Live TV is unusable because of this error.
As I mentioned in a previous post, reverting back to Plex Server 1.24.5173 sorted it for me. Of course YMMV.
and where can ver 1.24.5173 be found?
I found my Mac version on the Uptodown site. They cater for Windows too and seem trustworthy.
thanks, i also found a bunch of old versions at
https://www.filehorse.com/download-plex-media-server/53096/old-versions/
I found version 1.24.**5.**5173, which I think is the one you’re talking about. Hope it works.
Unfortunately 1.24.5.5173 did not help for me. I got the error just the 2nd time I changed the channel. I’m sure its not a hardware error as a simple restart of Plex fixes the error temporarily.
Hello, watching this issue as I have it as well, been having it since I bought by plex plass in summer of last year. Using the DVR Tuner: Hauppauge WinTV-dualHD I have seen this both on my build from scratch for plex ubuntu based AMD Ryzen 3 setup and on a raspberry PI ubuntu setup. Let me know if additional logs will help. In Austin, TX using the local TV listings here.
