you mean to do the following ? :
This ^^ is how to check DSM. The one thing which happens most often is DSM runs out of disk space itself. It is VERY rare but when DSM fails to run PMS, this is the most common cause.
I have storage space on my NAS HDD …
Anyway I do not understand what I have to do … I have to type a command line in SSH? or do something else?
@ChuckPa
In fact it is the command line “df” that had to be typed?
Is that what you wanted to see?
XXXX@MyDS216j:~$ sudo -su root
Password:
sh-4.3# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/md0 2385528 869292 1397452 39% /
none 254048 0 254048 0% /dev
/tmp 255936 820 255116 1% /tmp
/run 255936 2132 253804 1% /run
/dev/shm 255936 12 255924 1% /dev/shm
none 4 0 4 0% /sys/fs/cgroup
/dev/vg1000/lv 3840822576 2164475996 1676227796 57% /volume1
sh-4.3#
Ok.
here we go.
- Package Center – Stop Plex
- File Station – Plex / Library / Application Support / Plex Media Server
- Delete Preferences.xml
- Go into Logs
- Delete everything you see.
- Restart DSM
- Package Center
- Start Plex.
- Open http://ip.addr.of.syno:32400/web
- Claim and setup new
Ok I did everything you told me and it does not change anything … it still does not synology … I feel that I will have to install DSM again … #FeelLikeCrying
What is the IP address of your computer?
What is the IP address of your Synology?
Something VERY basic is wrong here.
I can give you that in PM
