Serial number: 00000000656c08a8
Crash ID: 4449, 6453, 106, 114 and countless others
Size of Raspberry Pi (256, 512): 512
Type of SD card: Kingston 8 GB SDHC class 10
Internet connection type: Ethernet
Version of RasPlex: 1.0.1 (also occurred on 1.0)
Log files: attached
How did you install rasplex? GUI installer on OS X
Best description you can give of the problem: When trying to play a TV show episode, RasPlex crashes and then displays the logo while rebooting. On the second try, it usually works. Tried with different shows and episodes, doesn’t seem to matter.
**Steps to reproduce: **Play media
Version of Plex Server: 0.9.15.2.1663-7efd046 (also occurred on a previous version)
**Type of Plex server: **Synology ds214play NAS
Power supply type and power rating: 5V, 3,1A USB power supply
Are you using a skin?
Yes! Plex Black Edition. Is that the problem?
Shouldn’t be causing a problem, I’m using the same version of PMS and Rasplex as you with Plex Black Edition and have no problems playing anything including high bitrate rips.
Have you tried reflashing your SD card, may have some corruption.
Also try setting secure connections to disabled in PMS, paricularly if your RPi is not a B2.
Regards
