Hello!
I lost one of my HDDs with bunch of files and the PMS installation/db folder. I am essentially starting over and not getting the option to specify an install volume - currently only installing to volume 3.
The new HDD on volume 4 is in the Synology DX-517 expansion bay that I have since added. Does it need to be located in main DS920+ bay to be seen by the PMS install?
Fairly sure I was prompted to select a volume when I created the PMS originally and have seen screenshots that show the option to pick a volume.
On DSM 7, it doesn’t matter anymore where the app is installed or where the PlexMediaServer shared folder is. You can safely move the shared folder at any time you need to reorganize.
By default, the shared folder is created wherever the app code is installed.
When you want to move the shared folder, Control Panel - EDIT the shared folder → Select the volume you want it on. DSM will do the rest
