Server Version#: v1.20.1.3252-a78fef9a9
Player Version#: App version: 8.5.1.19778 (810865696)
Everything set to Direct Play
Client:
08-31 14:02:37.268 i: Hello, Plex for Android world (debug: false)! 08-31 14:02:37.269 i: App version: 8.5.1.19778 (810865696) 08-31 14:02:37.270 i: Nano server version: 1.19.5.3006-da9510f6b 08-31 14:02:37.272 i: Manufacturer: Philips Device: PH7M_EU_5596 Model: TPM171E Product: PH7M_EU_5596 Version: 8.0.0
Server running in Docker:
Aug 31, 2020 04:38:42.249 [0x7f06f99de700] INFO - Plex Media Server v1.20.1.3252-a78fef9a9 - Docker Docker Container (LinuxServer.io) x86_64 - build: linux-x86_64 debian - GMT 00:00 Aug 31, 2020 04:38:42.252 [0x7f06f99de700] INFO - Linux version: 4.19.0-0.bpo.9-amd64, language: en-US Aug 31, 2020 04:38:42.252 [0x7f06f99de700] INFO - Processor Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
Whenever I try to play a movie in HEVC in 5 out of 10 cases it fails, by crashing and rebooting the TV. This does not happen when playing via KODI and streaming via SMB.
I think this happens if a movie has a bit rate higher than bitrate=“5000”.
Client logs don;t show anything
08-31 14:59:58.465 i: [FFmpeg] [INFO] Container metadata entries found: 3.
08-31 14:59:58.468 i: [FFmpeg] [INFO] Stream metadata entries found: 14.
08-31 14:59:58.470 i: [FFmpeg] [INFO] Stream metadata entries found: 15.
08-31 14:59:58.476 i: [FFmpeg] [INFO] Stream metadata entries found: 17.
08-31 14:59:58.531 i: [ExoPlayer][EventLogger] audioSessionId [2.86, 0.00, window=0, 89]
08-31 14:59:58.626 i: [Player] onDisplaySizeChanged(1920x800 at 0x0)
08-31 14:59:58.629 i: [Player][DimensionsLayout] Resizing: 1920 x 800
08-31 14:59:58.632 i: [ExoPlayer][EventLogger] videoSizeChanged [2.96, 0.00, window=0, 1920, 800]
08-31 14:59:58.638 i: [ExoPlayer][EventLogger] renderedFirstFrame [2.96, 0.00, window=0, Surface(name=null)/@0x9bf0135]
08-31 14:59:58.703 i: [ExoPlayer][EventLogger] surfaceSizeChanged [3.03, 0.00, window=0, 1920, 800]
08-31 15:00:11.755 i: [pms] /192.168.1.9:56157 - GET /logging
08-31 15:00:51.611 i: [pms] /192.168.1.9:56177 - GET /logging
CRASH
08-31 15:01:42.830 i: [ExoPlayer][EventLogger] state [107.16, 51.58, window=0, true, READY]
08-31 15:01:42.839 i: [EngineEventManager] onBufferingEnded
08-31 15:01:42.882 i: [EngineEventManager] onPlaybackStarted: Delay-29975238
08-31 15:01:42.894 i: [MetricsLatencyBehaviour] Latency recorded for playback: 107304
08-31 15:01:44.636 i: [InitializationMonitor] App created
08-31 15:01:44.943 i: [Boot] FragmentWithBehavioursDelegate took 0ms to run create behaviours.
08-31 15:01:44.945 i: [Boot] FragmentWithBehavioursDelegate took 1ms to run create behaviours.
08-31 15:01:44.946 i: Creating PreplayMovieActivity.
08-31 15:01:45.148 i: ------------------------------
08-31 15:01:45.149 i: Hello, Plex for Android world (debug: false)!
08-31 15:01:45.150 i: App version: 8.5.1.19778 (810865696)
08-31 15:01:45.154 i: Nano server version: 1.19.5.3006-da9510f6b
Thanks for any help.
UPDATE: Example if the move has 2 audio streams ACC7.1 and HE-ACC the later plays without crash. The default ACC 7.1 crashes.
Plex Media Server Logs_2020-08-31_14-02-10.zip (984.0 KB) Plex Andriod TV.txt (1.0 MB)
