Creation of TV "collections"
I’ve been creating collections for my movies, with no problems.
Under the Plex helps area, it clearly states that collections can also be created for TV shows, but when I open the Tag window to create a TV show collection, there is no option for collections.
Why does the support page state that collections can be created for TV shows, when clearly that is not possible.
It is possible. I’m not sure what you are editing, but it needs to be at the TV show level, not the episode level.
Actually TV shows can be placed into collections just fine but only at the show level not at the episode level.
I do think that it should be available at the episode level but the use I see for that is equally well served by playlists I guess.
I am at the episode level, an the only thing there is under tags is the “Writers” an “Directors” boxes?
Edit the show, not the episode.
The “Show” level NOT the episode level as you have already been told.
Got it!
That sucks!
I was hoping the group things like “Xmas” Shows etc.
You can use playlists, I think, for that.
I’ve used play lists for movies, but the problem with those, is no one but me can see them. Probably the same for TV shows I’ll bet. Friends and Family can’t see play lists.
