Cross border tv guide (US / Canada)
I live in an area where I have access the Canadian and US channels with my antenna. The problem is I am not able to get the complete guide. When I use my own Canadian zip code I am missing some US channels and when I use a close by US zip code I am missing some Canadian channels.
Is there a way to setup part of my channels as Canadian channels and others as US channels?
Hi Pierre
I’m in the same boat but did not have any problems with this. I’ll check how my locale is configured tonight and post it here.
I can’t seem to find the config details. I’m pretty sure I used my Canadian location (Montreal) and I have local channels as well as Vermont’s lineup
Weird, GTA here. When I put in my postal code, I get all the Toronto, Hamilton and Buffalo / Grand Island channels as I would expect.
@mkmorris and @mathieugfortin just want to make sure I understand. You use OTA antenna into your plex setup…and you put in your postal code and you get the correct channel listings for the mix of both Canadian channels (ie. CBC, Global etc) along with the American channels (ie. NBC, Fox, ABC etc)??? If so, that is my ideal!
I’m not sure if we can solve it (but great that some folks lineup seem to be accurate) I can try to talk to our metadata provider. (but it’s hard for them to know exactly what people can get)
In the meantime, what you could do is use XMLTV using Schedules Direct, you can pick lineups you can access and it will combine one XMLTV file… you have to pay extra for Schedules Direct but it might work. I haven’t tried it, but heard this from others.
