Tuning my channels
Hi, I bought the silicondust hdhomerun installed it. I live in Canada near the us border so I watch Canadian and US tv over the air. How do I program plex to have the US and Canadian program guide. Right now I have to choose from one or the other…
When I search for channels, plex finds them all but I can’t configure them as/in program guide!
D.
Try different postal codes. I’m in the same situation as you and I found one that filled up all the channels including the US ones. Try postal codes near the border, mid way between the canadian and USA transmitters sites.
What market are you in? If you are in Montreal area, use this postal code: J0J 1L0
I tried south shore of Montreal and also some city’s over the border and I can’t add all the channel to program guide… I will try the postal code you suggested!
What provider did you choose?
Local Over the Air Broadcast
Got it thanks!
It’s working !
Thanks a lot
I suggest that you fill up this form so Gracenote get notified that you postal code isn’t working. I did it for mine.
https://forums.plex.tv/discussion/281569/reporting-gracenote-epg-data-issues#latest
Will do, thanks
