Hi, I have a Lifetime Plex Pass. I’m not able to access, to turn on, the cross fade or the sweete fade in my music library. Can someone help me?
Thanks,
- you can only use it in Android mobile and iOS and Plexamp
- Has your music library been analysed for loudness? (Settings - Server - Library - ‘Analyze audio tracks for loudness’ = “As a scheduled task…”)
In Android mobile, tap on this area:
Thanks, I found it and I also tried Plexamp (that I don’t love…but it’s a my problem).
I use a PC and a Shield TV as plex-servers and I use to “cast” the music to other devices using the smartphone or the PC. So, do you know if it’s possible to have the sweet fade working on Shield TV or when I transmit music from my smartphone to other devices (google cast)? I understand that’s not possible but many times I wrong…
Correct, there is no way to have leveling and overlapping when casting.
There is only one way to get it, but it requires some tinkering: There is an alpha version of Plexamp for Raspberry Pi3, which runs head-less (i.e. you always need a different Plex app to cast a music playist to it.)
