Server Version#: 1.19.1.2589
Player Version#: n/a
Tuner Make/Model: haupauge WinTV-dualHD
Guide/Lineup name: missing
Using XMLTV?: not that i am aware off
Channel number/Name: n/a
I live in Denmark.
So my local cable provider kicked out a larger provider and now i am unable to search for channels.
First i tried to scan with my old provider “yousee” but that yielded an incorrect list and the guides did not match up, or i am missing a lot of channels.
My new provider is called “Ringsted AntenneForening” and provides something called “Canal Digital”
There is allready a “Canal Digital Gorlev” (gorlev is the name of a small town, i live in Ringsted one of the larger cities.) This does not yield any result.
I have all the settings that should be nessery to find the channels but for some reacon i cannot just put the into plex but have to use a preset the settings required are as follows:
Operatør: Andet (operator: other)
Netværk-id: 100 (network-id:100)
Frekvens kHz: 450000 (frequency kHz: 450000
Symbol rate: 6875
Any and all help would be much appreciated. ( my tuner has worked perfectly for the last year with my old provider )
