Server Version#: 1.15.3.876
Player Version#: 3.83.1
I am completely confused on this issue and I cannot solve it for some reason. Daily Show 2019-04-01 episode on two different platforms, I have Plex Media Server 1.15.3.876 on a Windows 10 machine and I have a Seedbox running Plex Media Server running 1.15.3.876, which is not being analyzed the same on both platforms, with the Windows 10 one being the problem. The files are named pretty much exactly the same (past the resolution of the files) but yet the Windows 10 will not scan the file with show information correctly.
This is the Seedbox Plex Media server:
This is the Windows 10 Plex Media server:
Both Plex servers have the same items setup for Show agent scanning:
Seedbox Plex server:
Windows 10 Server:
I have removed my TV show section from the Windows 10 machine and let Plex rescan in my shows and still not scanning in correctly. I then removed the directory from the TV shows directory and let Plex remove the shows from the TV library and then cleared the trash and then moved it back and let Plex scan them back in and still not showing the show info. If anyone has any suggestion or solution since I cannot determine any easy way to scan individuals shows in plex just the entire show. I will note, not all the episodes are showing this but enough of them to be an issue. Thank you.
