Server Version#: 3.57.1
Player Version#: N/A
I’m still getting used to this new forum software, so I hope I’m posting in the right section and that I didn’t miss a solution to my problem posted before. (btw, I’ve posted on these forums before, but it must have gotten lost in migration)
Anyway, I’m having an peculiar issue. I’ve had a TV section on my server for years now, but with Netflix kicking ass and all, has fallen into disuse a bit. I recently dusted it off added a new show to it, but it is not appearing in my list. After trying to re-add the show, changing the scanner agent from (and back to) the TVDB, I searched these forums and the web for solutions, but all to no avail.
What happens is that when I add the new show, it is recognizing them as duplicates of TV shows already in my library. I’ve used the same naming convention as I did with the shows that were already in my library, but since they deviated slightly from your recommended naming convention, I altered some to see if that would fix it, but again, no luck.
I ended up emptying out the directory that Plex scans entirely, re-scanning the library, Optimize the databases, Clean bundles, and then copy just the new show into the folder and re-scan. This worked…but only for the new show. When I tried adding back the previous shows, it all made it part of the same show (making up new seasons and episodes to make it work).
So, Plex considers the following two files to be copies of the same show/ episode:
TV\HD\The Handmaids Tale\S01\The.Handmaids.Tale.S01E01.720p.BluRay.x264-YELLOWBiRD\The.Handmaids.Tale.S01E01.720p.BluRay.x264-YELLOWBiRD.mkv
TV\HD\Fringe\S01\Fringe.S01E01.720p.BluRay.x264-SiNNERS\Fringe.S01E01.720p.BluRay.x264-SiNNERS.mkv
The Handmaids Tale is the new show, so both currently show as S01E01 for that. Fringe is exactly the way I had it in my library for years. Again, changing it to the following didn’t split the shows apart:
TV\HD\Fringe\Season 01\Fringe - S01E01.mkv
What has changed in the scanner since I last used Plex to watch new TV shows? And what do I need to do to get it back to work again?
Thanks in advance,
