Server Version#:1.13.8.5395
Player Version#:not known
Hey I have looked at the install page and installed Plex on my Debian 9 server. I can load the webui it says download media server, so I did and installed the .Deb file. When I load the webui it has no servers and no way of adding them. I had to use Ubuntu files as there was no Debian files. I have restarted Plex and makes no difference.
Really sorry, I’m a newbie I can so most stuff by coping and pasting commands I find on the net.
Any chance you could simplify it a bit so I can follow. I have android TV that I want to stream to with Plex installed do I need to ssh to that? I normally use putty to use for commands. Also do I need to use a web browser in putty? Never done that before is that’s the case.
Again really sorry to be a pain but I do appreciate it loads.
I edited your post to protect your privacy and host.
It should be the second one:
ssh -L 8888:127.0.0.1:32400 vps.ip.addr.here
What this does is create a tunnel in the SSH session, connecting port 8888 on your computer to port 32400 on the VPS which is precisely what we need to do.
No it did not work. I think I’ll have to leave it can’t work it out. I installed rutorrent today on Debian and got that working, you would think I could work this out lol.
Just want to say thanks loads for going out your way to help, not many people would… appreciated
Hey, I’m on Debian 9 with full root it’s only a cheap VPS to test stuff on.
Do you mind if I pm you, only reason I want to give you examples with my real details.
But if not I’m just stuck on what you do to add a server. I logged in via putty like you said and then went to the Plex webui and still no servers showing.
