Plex new Installation
Server Version#: 4.10.1
I have installed properly the plex server on debain 10. when i launch the plex web app, it not showing setup screen. i am not able to give path for my media files or make any settings. its directly going to home screen. in home screen left panel there is your-media option. click on that its asking to install server. i am already on server. checked with chrome firfox…
can anybody help
Are you loading the web app from app.plex.tv (which can be used AFTER setup)
-or-
http://127.0.0.1:32400/web - same machine
http://lan.ip.of.server:32400/web - somewhere on your LAN
I have installed it on VPS. and accessing it from my browser using the hostname with port…
ok… so it’s remote.
you need to use the SSH tunnel technique:
Scroll down to On a Different Network
