Having the same problem as a number of people above with the installation. I'd like to upload my logs but neither the basic nor the advanced uploader are able to complete the upload and i don't feel like opening a dropbox account. How can I send you the log files? Why should it be so difficult to attach 2 small files to this message? Thanks for any help.
@JGaryJ - Did you try out Plex even though you got the cursed error message? I had the same problem and after scratching my head withthe same challenges as you (although I did have a dropbox account), I just tried it out on my Roku box - and lo and behold it worked. So I suggest trying it out and see.
@navelgazer - Thanks for the tip. I'm checking out my photos on the tv through the roku...it seems to be working pretty well in spite of the error message. Hopefully everything's right. Time will tell. Thanks again.
@Chrispowel26 - see above posts. Try it out and see if it works. Has for few of us.
yeah same here, gave some error that it wasnt working, but lo and behold i added a folder and then videos to it, and can now access it from my roku 2 player. pretty nifty id say. but it does come up with an error initally and i would first add and folder and video, and see if it works before posting any log files.
i think some else here said the same thing " see things out and tryit first"
i feel like a nerd and this thing is free??? wow this is like my own little netflix server. is there a way to queue up links only???? i dont want to download videos all the time. i just want to serve up links and start playing it on the roku player. there has to be a way,?!?!
I received "A problem has been detected with a core component of Plex" as a result of installing. I have attached the Plex Media Server.log
Just so I'm clear, this error is displayed during setup? If so, can you follow the troubleshooting steps in the initial post on this thread?I received "A problem has been detected with a core component of Plex" as a result of installing. I have attached the Plex Media Server.log
Found the error, had failed to install newest version of Flash.
Uninstalled and reinstalled Plex without problems.
Hello, just got this massage:
A problem has been detected with a core component of Plex. Please visit the forums and provide your logs, as described here.
Please help me what to do next. Enclosed are my log files from the location:
C:\Users\yourusername\AppData\Local\Plex Media Server\Logs\
Im running Windows 7 64 bit
/Niklas
Think its when one tries to setup their first section so its displayed in plex/web.
I vaguely remember getting this error when migrating from OSX to Windows 7 and literally nothing was affected by this, all 100% functional. I had thought it was the migration which caused the issue but i have read a few people with this issue.
Installer packages built with the latest versions of WiX do require an updated version of Windows Installer. Unfortunately, Microsoft decided to not provide that to XP users as an automatic update. mudycj's link above should work.
I apologize for the hassle on XP, but this is not our fault. It's a 12-year old operating system and it's falling out of mainstream support from it's manufacturer.
Yeah, this is complex. Why did this installer require newer version of MSI? :(
I think I will have to wait to run a Plex server. I never had this problem with other software installers. :(
You might want to get comfortable with it. With Microsoft throwing in the towel on XP, you will be finding a lot of things difficult to install. And it should not come as a surprise, since it was announced about a decade ago. In fact, they extended the end-of-days for XP five years ago when the party was supposed to end.
I wanted to give a try at PMS.
First I had major problems downloading the setup file: many disconnections broken the setup file, and I solved (perhaps?) only with a download manager.
By launching the setup, however, I had immediately an error, which log report below.
I think is a problem of the setup file: there is a mirror where I can find a correct one?
Many thanks!
[10B8:0B3C][2013-08-31T08:05:21]i001: Burn v3.7.1224.0, Windows v6.2 (Build 9200: Service Pack 0), path: D:\JD\Plex-Media-Server-0.9.805.165-c301c50-en-US.exe, cmdline: ''
[10B8:0B3C][2013-08-31T08:05:21]i000: Initializing string variable 'InstallFolder' to value '[ProgramFilesFolder]Plex\Plex Media Server'
[10B8:0B3C][2013-08-31T08:05:21]i000: Initializing string variable 'LaunchTarget' to value '[InstallFolder]\Plex Media Server.exe'
[10B8:0B3C][2013-08-31T08:05:21]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Maurizio\AppData\Local\Temp\Plex Media Server_20130831080521.log'
[10B8:0B3C][2013-08-31T08:05:21]i000: Setting string variable 'WixBundleOriginalSource' to value 'D:\JD\Plex-Media-Server-0.9.805.165-c301c50-en-US.exe'
[10B8:0B3C][2013-08-31T08:05:21]i052: Condition '((VersionNT >= v5.1) AND (ServicePackLevel >= 3)) OR ((VersionNT >= v5.2) AND (ServicePackLevel >= 2)) OR (VersionNT >= v6.0)' evaluates to true.
[10B8:0B3C][2013-08-31T08:05:21]i000: Setting string variable 'WixBundleName' to value 'Plex Media Server'
[10B8:0B3C][2013-08-31T08:05:21]i100: Detect begin, 1 packages
[10B8:0B3C][2013-08-31T08:05:21]i101: Detected package: pms, state: Absent, cached: None
[10B8:0B3C][2013-08-31T08:05:21]i199: Detect complete, result: 0x0
[10B8:0B3C][2013-08-31T08:05:22]i200: Plan begin, 1 packages, action: Install
[10B8:0B3C][2013-08-31T08:05:22]i000: Setting string variable 'WixBundleRollbackLog_pms' to value 'C:\Users\Maurizio\AppData\Local\Temp\Plex Media Server_20130831080521_0_pms_rollback.log'
[10B8:0B3C][2013-08-31T08:05:22]i000: Setting string variable 'WixBundleLog_pms' to value 'C:\Users\Maurizio\AppData\Local\Temp\Plex Media Server_20130831080521_0_pms.log'
[10B8:0B3C][2013-08-31T08:05:22]i201: Planned package: pms, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[10B8:0B3C][2013-08-31T08:05:22]i299: Plan complete, result: 0x0
[10B8:0B3C][2013-08-31T08:05:22]i300: Apply begin
[15CC:03D8][2013-08-31T08:05:24]i360: Creating a system restore point.
[15CC:03D8][2013-08-31T08:05:24]i361: Created a system restore point.
[15CC:03D8][2013-08-31T08:05:24]i000: Caching bundle from: 'C:\Users\Maurizio\AppData\Local\Temp\{67b00c55-8e27-4ba5-b951-cc3208d50056}\.be\pms.exe' to: 'C:\ProgramData\Package Cache\{67b00c55-8e27-4ba5-b951-cc3208d50056}\pms.exe'
[15CC:03D8][2013-08-31T08:05:24]i320: Registering bundle dependency provider: {67b00c55-8e27-4ba5-b951-cc3208d50056}, version: 0.9.805.0
[10B8:19F8][2013-08-31T08:05:24]e000: Error 0x80004005: Failed to extract all files from container.
[10B8:0B10][2013-08-31T08:05:24]e000: Error 0x80004005: Faild to begin and wait for operation.
[10B8:0B10][2013-08-31T08:05:24]e000: Error 0x80004005: Failed to extract payload: a0 from container: WixAttachedContainer
[10B8:0B10][2013-08-31T08:05:24]e312: Failed to extract payloads from container: WixAttachedContainer to working path: D:\JD\Plex-Media-Server-0.9.805.165-c301c50-en-US.exe, error: 0x80004005.
[10B8:0B3C][2013-08-31T08:05:24]e000: Error 0x80004005: Failed while caching, aborting execution.
[15CC:03D8][2013-08-31T08:05:24]i330: Removed bundle dependency provider: {67b00c55-8e27-4ba5-b951-cc3208d50056}
[15CC:03D8][2013-08-31T08:05:24]i352: Removing cached bundle: {67b00c55-8e27-4ba5-b951-cc3208d50056}, from path: C:\ProgramData\Package Cache\{67b00c55-8e27-4ba5-b951-cc3208d50056}\
[10B8:0B3C][2013-08-31T08:05:25]i399: Apply complete, result: 0x80004005, restart: None, ba requested restart: No
I think is a problem of the setup file: there is a mirror where I can find a correct one?Many thanks!
[10B8:0B3C][2013-08-31T08:05:21]i001: Burn v3.7.1224.0, Windows v6.2 (Build 9200: Service Pack 0), path: D:\JD\Plex-Media-Server-0.9.805.165-c301c50-en-US.exe, cmdline: '' [10B8:0B3C][2013-08-31T08:05:21]i000: Initializing string variable 'InstallFolder' to value '[ProgramFilesFolder]Plex\Plex Media Server' [10B8:0B3C][2013-08-31T08:05:21]i000: Initializing string variable 'LaunchTarget' to value '[InstallFolder]\Plex Media Server.exe' [10B8:0B3C][2013-08-31T08:05:21]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Maurizio\AppData\Local\Temp\Plex Media Server_20130831080521.log' [10B8:0B3C][2013-08-31T08:05:21]i000: Setting string variable 'WixBundleOriginalSource' to value 'D:\JD\Plex-Media-Server-0.9.805.165-c301c50-en-US.exe' [10B8:0B3C][2013-08-31T08:05:21]i052: Condition '((VersionNT >= v5.1) AND (ServicePackLevel >= 3)) OR ((VersionNT >= v5.2) AND (ServicePackLevel >= 2)) OR (VersionNT >= v6.0)' evaluates to true. [10B8:0B3C][2013-08-31T08:05:21]i000: Setting string variable 'WixBundleName' to value 'Plex Media Server' [10B8:0B3C][2013-08-31T08:05:21]i100: Detect begin, 1 packages [10B8:0B3C][2013-08-31T08:05:21]i101: Detected package: pms, state: Absent, cached: None [10B8:0B3C][2013-08-31T08:05:21]i199: Detect complete, result: 0x0 [10B8:0B3C][2013-08-31T08:05:22]i200: Plan begin, 1 packages, action: Install [10B8:0B3C][2013-08-31T08:05:22]i000: Setting string variable 'WixBundleRollbackLog_pms' to value 'C:\Users\Maurizio\AppData\Local\Temp\Plex Media Server_20130831080521_0_pms_rollback.log' [10B8:0B3C][2013-08-31T08:05:22]i000: Setting string variable 'WixBundleLog_pms' to value 'C:\Users\Maurizio\AppData\Local\Temp\Plex Media Server_20130831080521_0_pms.log' [10B8:0B3C][2013-08-31T08:05:22]i201: Planned package: pms, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register [10B8:0B3C][2013-08-31T08:05:22]i299: Plan complete, result: 0x0 [10B8:0B3C][2013-08-31T08:05:22]i300: Apply begin [15CC:03D8][2013-08-31T08:05:24]i360: Creating a system restore point. [15CC:03D8][2013-08-31T08:05:24]i361: Created a system restore point. [15CC:03D8][2013-08-31T08:05:24]i000: Caching bundle from: 'C:\Users\Maurizio\AppData\Local\Temp\{67b00c55-8e27-4ba5-b951-cc3208d50056}\.be\pms.exe' to: 'C:\ProgramData\Package Cache\{67b00c55-8e27-4ba5-b951-cc3208d50056}\pms.exe' [15CC:03D8][2013-08-31T08:05:24]i320: Registering bundle dependency provider: {67b00c55-8e27-4ba5-b951-cc3208d50056}, version: 0.9.805.0 [10B8:19F8][2013-08-31T08:05:24]e000: Error 0x80004005: Failed to extract all files from container. [10B8:0B10][2013-08-31T08:05:24]e000: Error 0x80004005: Faild to begin and wait for operation. [10B8:0B10][2013-08-31T08:05:24]e000: Error 0x80004005: Failed to extract payload: a0 from container: WixAttachedContainer [10B8:0B10][2013-08-31T08:05:24]e312: Failed to extract payloads from container: WixAttachedContainer to working path: D:\JD\Plex-Media-Server-0.9.805.165-c301c50-en-US.exe, error: 0x80004005. [10B8:0B3C][2013-08-31T08:05:24]e000: Error 0x80004005: Failed while caching, aborting execution. [15CC:03D8][2013-08-31T08:05:24]i330: Removed bundle dependency provider: {67b00c55-8e27-4ba5-b951-cc3208d50056} [15CC:03D8][2013-08-31T08:05:24]i352: Removing cached bundle: {67b00c55-8e27-4ba5-b951-cc3208d50056}, from path: C:\ProgramData\Package Cache\{67b00c55-8e27-4ba5-b951-cc3208d50056}\ [10B8:0B3C][2013-08-31T08:05:25]i399: Apply complete, result: 0x80004005, restart: None, ba requested restart: No
Surely if a download is getting a lot of interruptions that must tell you that you do not have a good and reliable internet connection. Fix that first and then look into running apps like PMS. Normally the error you get is associated with a corrupt setup file.
Translating the version numbers in the log shows you are installing on windows 8. There have been other install errors on windows 8 reported by users and the related to windows 8 firewall being required plus other issues - expected to be fixed in windows 8.1. You can search the plex forums using google for plex and windows 8 install or setup errors.
Seriously - you should look into the reliability of your internet connection - perhaps changing ISPs !
For now - delete all browser cache and temporary download files and start a fresh to download PMS 0.9.8.5 for windows from here. I am going to update your other post with this response as well.
Many thanks for your answer.
I've got no problem with my internet connection: is not at the top for speed, but normally is stable and without problem.
My impression is that the server where the PMS setup file is on is very busy, not?
Can someone post the setup file on another site?
Hope you have your problems resolved. I have never had any download issues with PMS download site and I have not come across anyone else saying there is a problem since I started on plex 2 months ago.
cnet appear to host it but probably have to wait a while before 0.9.8.5 gets there.
may be someone else can offer you better advice
The file is 60 Mb in size - which is nothing when using an ISP offering fibre / cable broadband. But I am lucky I suppose to live in an area where that is available
Not sure if I'm posting this to the right place as It's my first post
I have plex server running on my DS412+
I have numerous mobile devices connected to it no problem and running fine with android and iOS
I have a couple of playout device including a Roku 2XS, Sony SNMP200 and an android cyclone device running no problem
I have also installed the plex player on my laptop and it runs with no problem
I have also build 2 identical machines and I had no problem with the install on these win7 64bit ultimate machines
My problem comes with only 1 of the identical machine that will run the app and allow me to use it no problem
however when it comes to playing any video it crashes out with an error message
I have tried everything I can thing of
No real errors in the event logs
No difference in the setups on either machine
No difference in the hardware other than an upgraded graphics card in the one that works
Anyway here is my event log from Plex and help would be most appreciated with this excellent piece of software
--- Event Log ---
--- Event Log ---
17:28:16 T:3324 M:33% NOTICE: -----------------------------------------------------------------------17:28:16 T:3324 M:33% NOTICE: Starting Plex 0.9.5.4, Platform: Windows 7, 64-bit (WoW) Service Pack 1 build 7601. Built on Jul 27 2012 (Git:3213059, compiler VC++ 1600)17:28:16 T:3324 M:33% NOTICE: AMD Athlon(tm) II X2 245 Processor17:28:16 T:3324 M:33% NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz17:28:16 T:3324 M:33% NOTICE: Running with restricted rights17:28:16 T:3324 M:33% NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Plex\Plex Media Center17:28:16 T:3324 M:33% NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Plex\Plex Media Center17:28:16 T:3324 M:33% NOTICE: special://masterprofile/ is mapped to: C:\Users\staff\AppData\Local\Plex\userdata17:28:16 T:3324 M:33% NOTICE: special://home/ is mapped to: C:\Users\staff\AppData\Local\Plex17:28:16 T:3324 M:33% NOTICE: special://temp/ is mapped to: C:\Users\staff\AppData\Local\Plex\cache17:28:16 T:3324 M:33% NOTICE: The executable running is: C:\Program Files (x86)\Plex\Plex Media Center\Plex.exe17:28:16 T:3324 M:33% NOTICE: Log File is located: C:\Users\staff\AppData\Local\Plex\Plex.log17:28:16 T:3324 M:33% NOTICE: -----------------------------------------------------------------------17:28:16 T:3324 M:33% NOTICE: Setup SDL17:28:16 T:3324 M:33% NOTICE: Found screen: Generic PnP Monitor on NVIDIA GeForce 7025 / NVIDIA nForce 630a, adapter 0.17:28:16 T:3324 M:33% NOTICE: Primary mode: 1920x1080 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 640x480 @ 75.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 720x480 @ 75.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 720x576 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 720x576 @ 75.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 800x600 @ 75.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1024x768 @ 75.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 1152x864 @ 75.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 1280x768 @ 75.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 1280x800 @ 75.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 1280x960 @ 75.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1280x1024 @ 75.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Previous line repeats 1 times.17:28:16 T:3324 M:33% NOTICE: Additional mode: 1600x900 @ 59.94 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1600x900 @ 59.94 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1600x1024 @ 59.94 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1600x1024 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1600x1024 @ 59.94 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1600x1024 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1600x1200 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1680x1050 @ 59.94 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen17:28:16 T:3324 M:33% NOTICE: load settings...17:28:16 T:3324 M:33% NOTICE: special://profile/ is mapped to: special://masterprofile/17:28:16 T:3324 M:33% NOTICE: loading special://masterprofile/guisettings.xml17:28:16 T:3324 M:33% NOTICE: Getting hardware information now...17:28:16 T:3324 M:33% NOTICE: Checking resolution 1217:28:16 T:3324 M:33% NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.17:28:16 T:3324 M:33% NOTICE: Loaded playercorefactory configuration17:28:16 T:3324 M:33% NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.17:28:16 T:3324 M:33% NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.17:28:16 T:3324 M:33% NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)17:28:16 T:3324 M:33% NOTICE: Default DVD Player: dvdplayer17:28:16 T:3324 M:33% NOTICE: Default Video Player: dvdplayer17:28:16 T:3324 M:33% NOTICE: Default Audio Player: paplayer17:28:16 T:3324 M:33% NOTICE: Loading media sources from special://masterprofile/sources.xml17:28:19 T:1104 M:33% NOTICE: Plex Source Scanner starting...(10.0.0.60) (uuid: d2c1d4af3463ce16721f86814038b99d228369fc)17:28:19 T:1104 M:33% NOTICE: Scanning remote server: 10.0.0.60 (remote: 0)17:28:19 T:1104 M:33% NOTICE: PlexDirectory::GetDirectory(http://10.0.0.60:32400/music)17:28:19 T:1104 M:33% NOTICE: PlexDirectory::GetDirectory(http://10.0.0.60:32400/video)17:28:19 T:1104 M:34% NOTICE: PlexDirectory::GetDirectory(http://10.0.0.60:32400/photos)17:28:19 T:1104 M:34% NOTICE: PlexDirectory::GetDirectory(http://10.0.0.60:32400/applications)17:28:19 T:1104 M:34% NOTICE: PlexDirectory::GetDirectory(http://10.0.0.60:32400/library/sections)17:28:19 T:1104 M:34% NOTICE: -> Local section 'Boxing' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'Combat' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'Contests' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'Exercises' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'Fitness' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'Gym-TV' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'H2N Music' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'H2N Photos' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'H2N Videos' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'Movies' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'Music' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'Training' found.17:28:19 T:1104 M:34% NOTICE: -> Local section 'UFC' found.17:28:19 T:1104 M:34% NOTICE: Scanning host 10.0.0.60 is complete.17:28:19 T:1104 M:34% NOTICE: Plex Source Scanner finished for host 10.0.0.60 (0 left)17:28:20 T:3324 M:35% NOTICE: initializing playlistplayer17:28:20 T:3324 M:35% NOTICE: DONE initializing playlistplayer17:28:20 T:3324 M:35% ERROR: DirectSoundCreate() Failed (0x88780078)17:28:20 T:3324 M:35% NOTICE: initialize done17:28:20 T:3324 M:35% NOTICE: Running the application...17:28:20 T:3324 M:35% NOTICE: Webserver: Starting...17:28:20 T:1472 M:35% NOTICE: PlexDirectory::GetDirectory(http://10.0.0.60:32400/library/arts)17:28:20 T:3324 M:35% NOTICE: WebServer: Started the webserver17:28:20 T:3324 M:35% NOTICE: ES: Starting event server17:28:20 T:3496 M:35% NOTICE: ES: Starting UDP Event server on 0.0.0.0:977717:28:20 T:3496 M:35% NOTICE: UDP: Listening on port 977717:28:28 T:2284 M:36% NOTICE: PlexDirectory::GetDirectory(http://127.0.0.1:32400)17:28:29 T:3324 M:36% WARNING: Window Translator: Can't find window settingscategory17:28:29 T:3324 M:36% ERROR: Error evaluating boolean expression !Window.Previous(0) + !Window.Previous(SettingsCategory) + !Window.Previous(1001) + !Window.Previous(130) + !Window.Previous(34)17:28:33 T:312 M:36% WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 717:28:33 T:312 M:36% ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.17:28:43 T:2284 M:36% NOTICE: PlexDirectory::GetDirectory(http://127.0.0.1:32400)17:28:47 T:3324 M:36% NOTICE: Storing total System Uptime17:28:47 T:3324 M:36% NOTICE: Saving settings17:28:47 T:3324 M:36% NOTICE: stop all17:28:47 T:3324 M:36% NOTICE: ES: Stopping event server17:28:47 T:3324 M:36% NOTICE: Webserver: Stopping...17:28:47 T:3324 M:36% NOTICE: WebServer: Stopped the webserver17:28:47 T:3324 M:36% NOTICE: Webserver: Stopped...17:28:48 T:3496 M:36% NOTICE: ES: UDP Event server stopped17:28:48 T:3324 M:36% NOTICE: stop sap announcement listener17:28:48 T:3324 M:36% NOTICE: clean cached files!17:28:48 T:3324 M:36% NOTICE: unload skin17:28:48 T:368 M:36% WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 717:28:48 T:368 M:36% ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.17:28:49 T:3324 M:35% NOTICE: stopped17:28:49 T:3324 M:35% NOTICE: destroy17:28:49 T:3100 M:35% ERROR: Network Service: Error in advertiser handle read: 995 (The I/O operation has been aborted because of either a thread exit or an application request) socket=-1
You ought to be posting in a different forum. It is neither a setup issue nor a windows PMS issue.
The log is for PMC (the Plex Media Center). You say there is an error message. You ought to give that out. The log file has error line ERROR: DirectSoundCreate() Failed (0x8878007 - which i am guessing is related to your problem. You can google this adding word plex and you will find hits on it which may explain the problem to you. I have not looked at the results but the following thread mentions PMC as opposed to XBMC
I believe you are in the Windows PMS Forum - you ought to be in the Plex Players Windows forum which covers PMC - see this forum
If you have a PMS issue then you would be using the PMS Synology forum
Thank you for pointing me in the right direction
I'm trying to upgrade to the latest version of the media server. I tried doing the update from within the server and it says I have the latest version, although I do not. So I tried to download the new version and installed and I get 0x80004005 - unspecified error. The log says:
