While trying to fix my problem, I had to restart because there were some pending Windows Updates that needed to install. I’m pretty sure I restarted before and was still unable to install the new Plex Media Server, but for some reason, I was able to install it now. When 0.9.12.19 was successful, I decided to try 0.9.14.x and it was successful too.
Thanks for all the quick replies, but it appears my Plex issue has been resolved now!
Thanks for the feedback. Normally pending restarts would give different symptom : stuck on initializing.
@asrusch said:
I am having problems with updating the PMS. I have restarted, repaired .NET, attempted to repair PMS (same error), but I keep getting the same:
[092C:1104][2015-11-23T10:22:47]e000: Error 0x80070660: Failed to install MSI package.
[092C:1104][2015-11-23T10:22:47]e000: Error 0x80070660: Failed to execute MSI package.
[06A4:04DC][2015-11-23T10:22:47]e000: Error 0x80070660: Failed to configure per-machine MSI package.
I cannot uninstall PMS, I get the same error. Help!
could you find this related log file and attach it C:\Users\Andy\AppData\Local\Temp\Plex Media Server_20151123102244_0_pms.log
was there any error prompt / dialogue box ?
what anti virus / anti malware / security / firewall software do you have running ?
Attached screenshot of install window. This is same error if I try and uninstall or repair.
The log file link in the install window was attached to my original post.
Running Windows 10 and built in Windows Defender as AV. I tried turning ON windows firewall (as i normally have it off), but that did not fix the problem.
I checked the Program Cache directory and the folders seem to be there and permissions are OK.
it is suggesting that it is free disk space or permissions issues on the temp folder
The second log file shows
MSI (c) (2C:68) [10:22:47:783]: MainEngineThread is returning 1632
and error 1632 is defined as
ERROR_INSTALL_TEMP_UNWRITABLE 1632 The Temp folder is either full or inaccessible. Verify that the Temp folder exists and that you can write to it.
how much free disk space is available?
what is the environment variable %temp% set to?
i would expect it to be C:\Users\Andy\AppData\Local\Temp\ as that is where the log files are going
I changed my Temp environment var to another drive with TBs free and a brand new folder. Ran the install again with same error.
Since it can write the log files to both E:\Temp and my Appdata\Local\Temp…I am assuming the permissions are fine and there are no space issues. That’s why I’m posting on here!
Cause
The NTFS file system permissions for the Administrators group or the System account no longer exist for the %SystemRoot%\Installer folder.
Note This issue may also occur if you have Read permissions for the %SystemRoot% folder. This condition stops Setup from creating the Installer folder.
Resolution
To resolve this issue, reset the NTFS permissions for the %SystemRoot%\Installer folder to include both the Administrators group and the System account:
In Windows Explorer, right-click the %SystemRoot%\Installer folder, and then click Properties.
Note The %SystemRoot%\Installer folder has hidden system attributes. To view the %SystemRoot%\Installer folder:
In Windows Explorer, on the Tools menu, click Folder Options, and then click the View tab.
Under Advance Settings, and then under Hidden Files and Folders, select Show hidden files and folders.
Click to clear the Hide protected operating system files check box, and then click OK.
In the %SystemRoot%\Installer Properties dialog box, click the Security tab. Verify the following permissions:
Administrators group - Full Control
Everyone group - Read and Execute, List Folder, Contents and Read
System account - Full Control
see if this helps. it is a windows environment issue as opposed to a plex issue
There we go! Turns out, for C:\Windows\Installer, there was a symbolic link to a location that did not exist. I removed the Sym Link, created the folder with the desired permissions, and was able to update!
(I think I created the link awhile ago to clear up space on my C: as it’s a SSD. Recently changed the drives that is E:, and since the Installer folder was hidden, I did not see and migrate that.)
@asrusch said:
There we go! Turns out, for whatever weird reason, for C:\Windows\Installer, there was a symbolic link to a location that did not exist. I removed the Sym Link, created the folder with the desired permissions, and was able to update!
Thank you VERY much for your help.
wow - excellent
it goes to show that google searching error codes does help
23 pages of problems.
The lesson here should be clear:
Windows installer is horrible. Plex is awesome. Needs to be updated to use a less draconian installer that doesn’t conflict with everything and waste huge amounts of disk space on our system drive.
Error 1714. The older version of Plex Media Server cannot be removed. Contact your technical support group. System Error 1612.
MSI (s) (CC:7C) [15:50:45:703]: User policy value ‘DisableRollback’ is 0
MSI (s) (CC:7C) [15:50:45:703]: Machine policy value ‘DisableRollback’ is 0
MSI (s) (CC:7C) [15:50:45:703]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
Action ended 15:50:45: RemoveExistingProducts. Return value 3.
MSI (s) (CC:7C) [15:50:45:703]: No System Restore sequence number for this installation.
MSI (s) (CC:7C) [15:50:45:703]: Unlocking Server
Action ended 15:50:45: INSTALL. Return value 3.
@rmussell said:
Looks like I’m on the same Strugglebus.
Here is my error log snippet.
How do I resolve this?
MSI (s) (CC:7C) [15:50:42:521]: Doing action: RemoveExistingProducts
MSI (s) (CC:88) [15:50:42:521]: Warning: Local cached package ‘C:\Windows\Installer\2173be88.msi’ is missing.
MSI (s) (CC:88) [15:50:42:521]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
MSI (s) (CC:88) [15:50:42:521]: SOURCEMGMT: Trying source C:\ProgramData\Package Cache{B4760EA0-17DF-4F24-89ED-97DDD2DB57A2}v0.9.1211.
MSI (s) (CC:88) [15:50:42:521]: Note: 1: 2203 2: C:\ProgramData\Package Cache{B4760EA0-17DF-4F24-89ED-97DDD2DB57A2}v0.9.1211\pms.msi 3: -2147287037
MSI (s) (CC:88) [15:50:42:521]: SOURCEMGMT: Source is invalid due to missing/inaccessible package.
MSI (s) (CC:88) [15:50:42:521]: Note: 1: 1706 2: -2147483647 3: pms.msi
MSI (s) (CC:7C) [15:50:45:703]: Product: Plex Media Server – Error 1714. The older version of Plex Media Server cannot be removed. Contact your technical support group. System Error 1612.
So the package files for the old version 0.9.12.11 are gone or inaccessible
If it is windows 10 or it gives you a chance to tell it where the pms.msi is then you could download 0.9.12.11 from here: https://plex.tv/downloads/1/archive and follow steps in option 2 in this post (substituting 0.9.12.11 file for the 0.9.12.8 file shown in the steps there)
“A problem has been detected with a core component of Plex Media Server.
Please visit the forums and provide your logs, as described here.”
So here I am.
So here I am.
The error is returned if the python bundles do not start in time. Normally such issues arise if there is a corrupt install or some security software / proxy / vpn software that is blocking the communication between the plex media server and the python components - it could also be firewall settings on the PC
Could you also upload the logs that got created in the Logs\PMS Plugin Logs folder
And look into what security software you have and if there is a vpn application running or proxy.
For the firewall make sure it has exceptions for all the plex media server exe files and separately to have in advanced settings an inbound port rule for tcp local port 32400 ( remote port : any, remote IP : any) and allow for all network profiles
To see if it is a corrupt install download plex media server afresh and check file properties to make sure you do see a digital signatures tab with entry for plex inc. run it again to do a repair - if that does not resolve the issue - run the repair again with anti virus software disabled and try again.
Get logs again uploaded if problem does get resolved and details of what security software is running and confirm no proxy or vpn application
I get "Windows cannot access the specified device, path or file. You may not have the appropriate permissions to access the item…
I tried to add permission, it is everything ok, it just doesnt works
