Hi.
Tried to install Plex Media Server on Windows 8.
Failed.
Here the log.
Thanks.
@pezzolesil@yahoo.it said:
Hi.
Failed.
Here the log.
Thanks.
The error is being generated when trying to install the Media Feature Pack for windows 8
[1834:1E44][2017-11-14T07:18:28]e000: Error 0x80240017: Failed to configure per-machine MSU package.
[1834:1E44][2017-11-14T07:18:28]i319: Applied execute package: MediaPackWin8x64, result: 0x80240017, restart: None
Make sure you are first up to date with windows update for recommended and important updates
There are probably some dependency on components that are not on your system
Have a look at this forum topic which is for the same issue
http://forums.plex.tv/discussion/228068/plex-wont-install-due-to-error-0x80240017-failed-to-execute-msu-package-mediapackwin8x64
Thanks sa2000,
problem solved. WMplayer not enabled.
Regards
I found this thread after trying to install several versions of Plex. It would go through the whole install process and say it installed successfully but it didn’t and clicking on the “Launch” button did absolutely nothing. Looked in the logs and had an “Error 0x80070002: Failed to launch target”. So I followed the OP’s instructions to a tee. I couldn’t get it to work with the MSIFASTINSTALL 7 option. I googled what that was and found options 0,1,2,4 but no 7! Duh binary! :D. So I tried changing the option to ‘0’ and bam! it finally installed after trying for hours to get it to do something. Props for the OP and point in the right direction!
I must say, I have never ever had such a hard time installing anything.To have to do all of this just to get a damn program installed, you gotta be kidding me. Damn, I know it is free but it is totally ridiculous!
As far as i know, “7” is a “MsiHiddenPropertie” which will write additional lines to a Log for debugging suppose
I’m still having major issues with an install. I’ve tried quite a few things, but still nothing is working. See my original thread for what I have done. Any assistance would be greatly appreciated.
Trying to install on win7 sp1 machine and get error code 0x81f40001. It’s not recognizing that it’s the sp1 version of win 7
Lets have a look at all the logs from this install
They would normally be in %Temp% and the filenames start with Plex Media Server_ and have file extension of .log - there would be a log file with name starting with dd_
Are you running the installer in a windows admin user account?
zip the logs and attach the zip
Couldn’t attach file so here’s the log file
[0A78:0A60][2018-04-08T14:16:28]i001: Burn v3.10.3.3007, Windows v6.1 (Build 7600: Service Pack 0), path: C:\Users\user\AppData\Local\Temp\{5920683D-FC13-48C6-AEFE-91EF212D2A61}\.cr\Plex-Media-Server-1.12.1.4885-1046ba85f.exe
[0A78:0A60][2018-04-08T14:16:28]i000: Initializing string variable 'OEM' to value ''
[0A78:0A60][2018-04-08T14:16:28]i000: Initializing string variable 'NOLAUNCH' to value ''
[0A78:0A60][2018-04-08T14:16:28]i000: Initializing string variable 'InstallFolder' to value '[ProgramFilesFolder]Plex\Plex Media Server'
[0A78:0A60][2018-04-08T14:16:28]i000: Initializing string variable 'LaunchTarget' to value '[InstallFolder]\Plex Media Server.exe'
[0A78:0A60][2018-04-08T14:16:28]i009: Command Line: '-burn.clean.room=C:\Users\user\Downloads\Plex-Media-Server-1.12.1.4885-1046ba85f.exe -burn.filehandle.attached=176 -burn.filehandle.self=184'
[0A78:0A60][2018-04-08T14:16:28]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\user\Downloads\Plex-Media-Server-1.12.1.4885-1046ba85f.exe'
[0A78:0A60][2018-04-08T14:16:28]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\user\Downloads\'
[0A78:0A60][2018-04-08T14:16:30]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\user\AppData\Local\Temp\Plex Media Server_20180408141630.log'
[0A78:0A60][2018-04-08T14:16:30]i000: Setting string variable 'WixBundleName' to value 'Plex Media Server'
[0A78:0A60][2018-04-08T14:16:30]i000: Setting string variable 'WixBundleManufacturer' to value 'Plex, Inc.'
[0A78:06C8][2018-04-08T14:16:31]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[0A78:06C8][2018-04-08T14:16:31]i000: Setting version variable 'WixBundleFileVersion' to value '1.12.1.4885'
[0A78:0A60][2018-04-08T14:16:32]i100: Detect begin, 16 packages
[0A78:0A60][2018-04-08T14:16:32]i000: Registry key not found. Key = 'Software\Plex, Inc.\Plex Media Server'
[0A78:0A60][2018-04-08T14:16:32]i052: Condition 'NOT PreviousInstallFolder' evaluates to true.
[0A78:0A60][2018-04-08T14:16:32]i052: Condition 'PreviousInstallFolder' evaluates to false.
[0A78:0A60][2018-04-08T14:16:32]i000: Setting numeric variable 'FoundMfPlatDll' to value 1
[0A78:0A60][2018-04-08T14:16:32]i000: File search: wfs7D9412D4C58B244C091F58CF1897F6B2, did not find path: C:\Windows\system32\ucrtbase.dll
[0A78:0A60][2018-04-08T14:16:32]i000: Setting numeric variable 'Found_ucrtbase_dll' to value 0
[0A78:0A60][2018-04-08T14:16:32]i052: Condition 'NOT Found_ucrtbase_dll' evaluates to true.
[0A78:0A60][2018-04-08T14:16:32]i000: File search: wfsF7FCAC4979A94D8A7F3947991BCD3BEE, did not find path: C:\Windows\system32\msvcp140.dll
[0A78:0A60][2018-04-08T14:16:32]i000: Setting numeric variable 'Bad_VCRedist' to value 0
[0A78:0A60][2018-04-08T14:16:32]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2919355~31bf3856ad364e35~amd64~~6.3.1.14'
[0A78:0A60][2018-04-08T14:16:32]i000: Registry value not found. Key = 'SOFTWARE\Microsoft\Windows NT\CurrentVersion', Value = 'ReleaseID'
[0A78:0A60][2018-04-08T14:16:32]i000: Setting string variable 'WinRegCurrentBuildNumber' to value '7600'
[0A78:0A60][2018-04-08T14:16:32]i000: Setting string variable 'WinRegInstallationType' to value 'Client'
[0A78:0A60][2018-04-08T14:16:32]i000: Setting string variable 'WinRegEditionID' to value 'Professional'
[0A78:0A60][2018-04-08T14:16:32]i000: Setting string variable 'WinRegProductName' to value 'Windows 7 Professional'
[0A78:0A60][2018-04-08T14:16:32]i000: Setting string variable 'WinRegMediaPlayer' to value '%ProgramFiles%\Windows Media Player'
[0A78:0A60][2018-04-08T14:16:32]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2919355~31bf3856ad364e35~x86~~6.3.1.14'
[0A78:0A60][2018-04-08T14:16:32]i000: Setting string variable 'WinRegCurrentBuild' to value '7600'
[0A78:0A60][2018-04-08T14:16:32]i052: Condition 'FoundMfPlatDll' evaluates to true.
[0A78:0A60][2018-04-08T14:16:32]i052: Condition 'FoundMfPlatDll AND WinRegMediaPlayer' evaluates to true.
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin7x86, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin7x64, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin8x86, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin8x64, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin81x86, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin81x64, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin10x86, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin10x64, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin10x861511, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin10x641511, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin10x861607, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: MediaPackWin10x641607, state: Present, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: pmsshutdown, state: Absent, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: vcredist_repair, state: Absent, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: vcredist, state: Absent, cached: None
[0A78:0A60][2018-04-08T14:16:32]i101: Detected package: pms, state: Absent, cached: None
[0A78:0A60][2018-04-08T14:16:32]i052: Condition 'VersionNT >= v6.1' evaluates to true.
[0A78:0A60][2018-04-08T14:16:32]i052: Condition 'NOT ((VersionNT = v6.1) AND ((NOT ServicePackLevel) OR (ServicePackLevel < 1)))' evaluates to false.
[0A78:0A60][2018-04-08T14:16:32]e000: Plex Media Server on Windows 7 and Server 2008 R2 requires Service Pack 1.
[0A78:0A60][2018-04-08T14:16:32]e000: Error 0x81f40001: Bundle condition evaluated to false: NOT ((VersionNT = v6.1) AND ((NOT ServicePackLevel) OR (ServicePackLevel < 1)))
[0A78:0A60][2018-04-08T14:16:32]i199: Detect complete, result: 0x0
[0A78:0A60][2018-04-08T14:17:50]i500: Shutting down, exit code: 0x1
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: Bad_VCRedist = 0
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: Found_ucrtbase_dll = 0
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: FoundMfPlatDll = 1
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: InstallFolder = C:\Program Files (x86)\Plex\Plex Media Server
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: LaunchTarget = C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Server.exe
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: NOLAUNCH =
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: OEM =
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: ProgramFilesFolder = C:\Program Files (x86)\
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: SystemFolder = C:\Windows\system32\
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: VersionNT = 6.1.0.0
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WinRegCurrentBuild = 7600
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WinRegCurrentBuildNumber = 7600
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WinRegEditionID = Professional
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WinRegInstallationType = Client
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WinRegMediaPlayer = %ProgramFiles%\Windows Media Player
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WinRegProductName = Windows 7 Professional
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleAction = 5
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleElevated = 0
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleFileVersion = 1.12.1.4885
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleInstalled = 0
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleLog = C:\Users\user\AppData\Local\Temp\Plex Media Server_20180408141630.log
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleManufacturer = Plex, Inc.
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleName = Plex Media Server
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleOriginalSource = C:\Users\user\Downloads\Plex-Media-Server-1.12.1.4885-1046ba85f.exe
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleOriginalSourceFolder = C:\Users\user\Downloads\
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleProviderKey = {b75df829-7b5f-4ff5-8fa7-97f261f23960}
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleSourceProcessFolder = C:\Users\user\Downloads\
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleSourceProcessPath = C:\Users\user\Downloads\Plex-Media-Server-1.12.1.4885-1046ba85f.exe
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleTag =
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixBundleVersion = 1.12.1.4885
[0A78:0A60][2018-04-08T14:17:50]i410: Variable: WixStdBALanguageId = 1033
[0A78:0A60][2018-04-08T14:17:50]i007: Exit code: 0x1, restarting: No
I am sorry this is what windows is saying - see first line
It should be 7601
See List of Microsoft Windows versions - Wikipedia
It is not a Plex issue
Howdy folks-
I had plex running here on my (now old) Win7 Ultimate box (x64, 64bit) for a couple months. Was pretty awesome.
For no apparent reason (probably user error somewhere) plex is no longer available- plex media server runs, but cannot/will not respond in any way- I can’t even get it to respond to the local loopback address. Several days back I posted
https://forums.plex.tv/discussion/318032/pms-not-functioning-tried-uninstall-reinstall-repair-no-joy explaining the deal. Any assistance or suggestions would be appreciated.
I’m going to start some deeper windows diagnostics, etc., but everything else is fine.
@“norman$$” said:
Howdy folks-I had plex running here on my (now old) Win7 Ultimate box (x64, 64bit) for a couple months. Was pretty awesome.
https://forums.plex.tv/discussion/318032/pms-not-functioning-tried-uninstall-reinstall-repair-no-joy explaining the deal. Any assistance or suggestions would be appreciated.I’m going to start some deeper windows diagnostics, etc., but everything else is fine.
responded here https://forums.plex.tv/discussion/comment/1659841/#Comment_1659841
I have problem upgrading PMS to 1.13.5.5291. Please help. The log is
[0E68:242C][2018-08-03T21:38:41]i001: Burn v3.10.3.3007, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\VIC-JA~1\AppData\Local\Temp\{2FF0DDA5-A01B-4496-B49D-5DF80192B817}\.cr\Plex-Media-Server-1.13.5.5291-6fa5e50a8.exe
[0E68:242C][2018-08-03T21:38:41]i000: Initializing string variable 'OEM' to value ''
[0E68:242C][2018-08-03T21:38:41]i000: Initializing string variable 'NOLAUNCH' to value ''
[0E68:242C][2018-08-03T21:38:41]i000: Initializing string variable 'InstallFolder' to value '[ProgramFilesFolder]Plex\Plex Media Server'
[0E68:242C][2018-08-03T21:38:41]i000: Initializing string variable 'LaunchTarget' to value '[InstallFolder]\Plex Media Server.exe'
[0E68:242C][2018-08-03T21:38:41]i009: Command Line: '"-burn.clean.room=C:\Users\Vic-Janet\AppData\Local\Plex Media Server\Updates\1.13.5.5291-6fa5e50a8\packages\Plex-Media-Server-1.13.5.5291-6fa5e50a8.exe" -burn.filehandle.attached=188 -burn.filehandle.self=196'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Vic-Janet\AppData\Local\Plex Media Server\Updates\1.13.5.5291-6fa5e50a8\packages\Plex-Media-Server-1.13.5.5291-6fa5e50a8.exe'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Vic-Janet\AppData\Local\Plex Media Server\Updates\1.13.5.5291-6fa5e50a8\packages\'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\VIC-JA~1\AppData\Local\Temp\Plex Media Server_20180803213841.log'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WixBundleName' to value 'Plex Media Server'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WixBundleManufacturer' to value 'Plex, Inc.'
[0E68:2B44][2018-08-03T21:38:41]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[0E68:2B44][2018-08-03T21:38:41]i000: Setting version variable 'WixBundleFileVersion' to value '1.13.5.5291'
[0E68:242C][2018-08-03T21:38:41]i100: Detect begin, 16 packages
[0E68:242C][2018-08-03T21:38:41]i000: Registry value not found. Key = 'Software\Plex, Inc.\Plex Media Server', Value = 'InstallFolder'
[0E68:242C][2018-08-03T21:38:41]i052: Condition 'NOT PreviousInstallFolder' evaluates to true.
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'PreviousInstallFolder' to value 'C:\Program Files (x86)\Plex\Plex Media Server\'
[0E68:242C][2018-08-03T21:38:41]i052: Condition 'PreviousInstallFolder' evaluates to true.
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'InstallFolder' to value 'C:\Program Files (x86)\Plex\Plex Media Server\'
[0E68:242C][2018-08-03T21:38:41]i000: Setting numeric variable 'FoundMfPlatDll' to value 1
[0E68:242C][2018-08-03T21:38:41]i000: Setting numeric variable 'Found_ucrtbase_dll' to value 1
[0E68:242C][2018-08-03T21:38:41]i052: Condition 'NOT Found_ucrtbase_dll' evaluates to false.
[0E68:242C][2018-08-03T21:38:41]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2919355~31bf3856ad364e35~amd64~~6.3.1.14'
[0E68:242C][2018-08-03T21:38:41]i000: Registry value not found. Key = 'SOFTWARE\Microsoft\Windows NT\CurrentVersion', Value = 'ReleaseID'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WinRegCurrentBuildNumber' to value '7601'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WinRegInstallationType' to value 'Client'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WinRegEditionID' to value 'Ultimate'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WinRegProductName' to value 'Windows 7 Ultimate'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WinRegMediaPlayer' to value '%ProgramFiles%\Windows Media Player'
[0E68:242C][2018-08-03T21:38:41]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2919355~31bf3856ad364e35~x86~~6.3.1.14'
[0E68:242C][2018-08-03T21:38:41]i000: Setting string variable 'WinRegCurrentBuild' to value '7601'
[0E68:242C][2018-08-03T21:38:41]i102: Detected related bundle: {703f6f53-a980-40a6-af98-742126fb8c87}, type: Upgrade, scope: PerMachine, version: 1.13.2.5154, operation: MajorUpgrade
[0E68:242C][2018-08-03T21:38:41]i052: Condition 'FoundMfPlatDll' evaluates to true.
[0E68:242C][2018-08-03T21:38:41]i052: Condition 'FoundMfPlatDll AND WinRegMediaPlayer' evaluates to true.
[0E68:242C][2018-08-03T21:38:41]i103: Detected related package: {81B13AD7-E284-4E48-A356-38418676244F}, scope: PerMachine, version: 1.13.2154.0, language: 0 operation: MajorUpgrade
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin7x86, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin7x64, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin8x86, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin8x64, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin81x86, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin81x64, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin10x86, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin10x64, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin10x861511, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin10x641511, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin10x861607, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: MediaPackWin10x641607, state: Present, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: pmsshutdown, state: Absent, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: vcredist_repair, state: Absent, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: vcredist, state: Absent, cached: None
[0E68:242C][2018-08-03T21:38:41]i101: Detected package: pms, state: Absent, cached: None
[0E68:242C][2018-08-03T21:38:41]i052: Condition 'VersionNT >= v6.1' evaluates to true.
[0E68:242C][2018-08-03T21:38:41]i052: Condition 'NOT ((VersionNT = v6.1) AND ((NOT ServicePackLevel) OR (ServicePackLevel < 1)))' evaluates to true.
[0E68:242C][2018-08-03T21:38:41]i052: Condition 'NOT ((VersionNT = v6.3) AND (KB2919355_x86 <> 112 AND KB2919355_amd64 <> 112))' evaluates to true.
[0E68:242C][2018-08-03T21:38:41]i199: Detect complete, result: 0x0
[0E68:2B44][2018-08-03T21:38:43]i000: Setting numeric variable 'EulaAcceptCheckbox' to value 0
[0E68:242C][2018-08-03T21:38:43]i200: Plan begin, 16 packages, action: Install
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT=v6.1 AND NOT VersionNT64 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin7x86
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT=v6.1 AND VersionNT64 AND WinRegInstallationType~="Client"' evaluates to true.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin7x64
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT=v6.2 AND NOT VersionNT64 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin8x86
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT=v6.2 AND VersionNT64 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin8x64
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT=v6.3 AND NOT VersionNT64 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin81x86
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT=v6.3 AND VersionNT64 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin81x64
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT>=v10.0 AND NOT VersionNT64 AND WinRegCurrentBuildNumber=10240 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x86
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT>=v10.0 AND VersionNT64 AND WinRegCurrentBuildNumber=10240 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x64
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT>=v10.0 AND NOT VersionNT64 AND WinRegReleaseID=1511 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x861511
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT>=v10.0 AND VersionNT64 AND WinRegReleaseID=1511 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x641511
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT>=v10.0 AND NOT VersionNT64 AND WinRegReleaseID=1607 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x861607
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'VersionNT>=v10.0 AND VersionNT64 AND WinRegReleaseID=1607 AND WinRegInstallationType~="Client"' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x641607
[0E68:242C][2018-08-03T21:38:43]i000: Setting string variable 'WixBundleRollbackLog_pmsshutdown' to value 'C:\Users\VIC-JA~1\AppData\Local\Temp\Plex Media Server_20180803213841_000_pmsshutdown_rollback.log'
[0E68:242C][2018-08-03T21:38:43]i000: Setting string variable 'WixBundleLog_pmsshutdown' to value 'C:\Users\VIC-JA~1\AppData\Local\Temp\Plex Media Server_20180803213841_000_pmsshutdown.log'
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'Bad_VCRedist' evaluates to false.
[0E68:242C][2018-08-03T21:38:43]w321: Skipping dependency registration on package with no dependency providers: vcredist_repair
[0E68:242C][2018-08-03T21:38:43]i052: Condition 'NOT Bad_VCRedist' evaluates to true.
[0E68:242C][2018-08-03T21:38:43]i000: Setting string variable 'WixBundleLog_vcredist' to value 'C:\Users\VIC-JA~1\AppData\Local\Temp\Plex Media Server_20180803213841_001_vcredist.log'
[0E68:242C][2018-08-03T21:38:43]i000: Setting string variable 'WixBundleRollbackLog_pms' to value 'C:\Users\VIC-JA~1\AppData\Local\Temp\Plex Media Server_20180803213841_002_pms_rollback.log'
[0E68:242C][2018-08-03T21:38:43]i000: Setting string variable 'WixBundleLog_pms' to value 'C:\Users\VIC-JA~1\AppData\Local\Temp\Plex Media Server_20180803213841_002_pms.log'
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin7x86, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin7x64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin8x86, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin8x64, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin81x86, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin81x64, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin10x86, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin10x64, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin10x861511, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin10x641511, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin10x861607, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: MediaPackWin10x641607, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: pmsshutdown, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: vcredist_repair, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: vcredist, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None
[0E68:242C][2018-08-03T21:38:43]i201: Planned package: pms, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[0E68:242C][2018-08-03T21:38:43]i207: Planned related bundle: {703f6f53-a980-40a6-af98-742126fb8c87}, type: Upgrade, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, dependency: None
[0E68:242C][2018-08-03T21:38:43]i299: Plan complete, result: 0x0
[0E68:242C][2018-08-03T21:38:43]i300: Apply begin
[0E68:242C][2018-08-03T21:38:43]i010: Launching elevated engine process.
[0E68:242C][2018-08-03T21:38:43]i011: Launched elevated engine process.
[0E68:242C][2018-08-03T21:38:43]i012: Connected to elevated engine.
[24F0:2BBC][2018-08-03T21:38:43]i358: Pausing automatic updates.
[24F0:2BBC][2018-08-03T21:38:43]i359: Paused automatic updates.
[24F0:2BBC][2018-08-03T21:38:43]i360: Creating a system restore point.
[24F0:2BBC][2018-08-03T21:38:43]i362: System restore disabled, system restore point not created.
[24F0:2BBC][2018-08-03T21:38:43]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ee1563ba-f9e1-4222-a38b-e88c26fc0f1c}, options: 0x7, disable resume: No
[24F0:2BBC][2018-08-03T21:38:43]i000: Caching bundle from: 'C:\Users\VIC-JA~1\AppData\Local\Temp\{BC5E140C-8F64-4328-8F9D-D4C7BC90BDDF}\.be\pms.exe' to: 'C:\ProgramData\Package Cache\{ee1563ba-f9e1-4222-a38b-e88c26fc0f1c}\pms.exe'
[24F0:2BBC][2018-08-03T21:38:44]i320: Registering bundle dependency provider: {ee1563ba-f9e1-4222-a38b-e88c26fc0f1c}, version: 1.13.5.5291
[24F0:2BBC][2018-08-03T21:38:44]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ee1563ba-f9e1-4222-a38b-e88c26fc0f1c}, resume: Active, restart initiated: No, disable resume: No
[24F0:02E4][2018-08-03T21:38:45]i305: Verified acquired payload: pmsshutdown at path: C:\ProgramData\Package Cache\.unverified\pmsshutdown, moving to: C:\ProgramData\Package Cache\{2505AB18-0108-47B3-B335-3FE067556E95}v1.13.5291\pms-shutdown.msi.
[24F0:02E4][2018-08-03T21:38:45]i305: Verified acquired payload: vcredist at path: C:\ProgramData\Package Cache\.unverified\vcredist, moving to: C:\ProgramData\Package Cache\72211BD2E7DFC91EA7C8FAC549C49C0543BA791B\vcredist_x86.exe.
[24F0:02E4][2018-08-03T21:38:45]i305: Verified acquired payload: pms at path: C:\ProgramData\Package Cache\.unverified\pms, moving to: C:\ProgramData\Package Cache\{82C831F3-71D9-482D-8A82-11B4FF679033}v1.13.5291\pms.msi.
[24F0:2BBC][2018-08-03T21:38:45]i323: Registering package dependency provider: {2505AB18-0108-47B3-B335-3FE067556E95}, version: 1.13.5291, package: pmsshutdown
[24F0:2BBC][2018-08-03T21:38:45]i301: Applying execute package: pmsshutdown, action: Install, path: C:\ProgramData\Package Cache\{2505AB18-0108-47B3-B335-3FE067556E95}v1.13.5291\pms-shutdown.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" INSTALLLOCATION="C:\Program Files (x86)\Plex\Plex Media Server\"'
[0E68:242C][2018-08-03T21:38:46]i319: Applied execute package: pmsshutdown, result: 0x0, restart: None
[24F0:2BBC][2018-08-03T21:38:46]i325: Registering dependency: {ee1563ba-f9e1-4222-a38b-e88c26fc0f1c} on package provider: {2505AB18-0108-47B3-B335-3FE067556E95}, package: pmsshutdown
[24F0:2BBC][2018-08-03T21:38:46]i301: Applying execute package: vcredist, action: Install, path: C:\ProgramData\Package Cache\72211BD2E7DFC91EA7C8FAC549C49C0543BA791B\vcredist_x86.exe, arguments: '"C:\ProgramData\Package Cache\72211BD2E7DFC91EA7C8FAC549C49C0543BA791B\vcredist_x86.exe" /install /quiet /norestart'
[0E68:242C][2018-08-03T21:39:02]i319: Applied execute package: vcredist, result: 0x0, restart: None
[24F0:2BBC][2018-08-03T21:39:02]i323: Registering package dependency provider: {82C831F3-71D9-482D-8A82-11B4FF679033}, version: 1.13.5291, package: pms
[24F0:2BBC][2018-08-03T21:39:02]i301: Applying execute package: pms, action: Install, path: C:\ProgramData\Package Cache\{82C831F3-71D9-482D-8A82-11B4FF679033}v1.13.5291\pms.msi, arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" OEM="" NOLAUNCH="" INSTALLLOCATION="C:\Program Files (x86)\Plex\Plex Media Server\" WINDOWSTYPE="Client"'
[24F0:2BBC][2018-08-03T21:39:59]e000: Error 0x80070643: Failed to install MSI package.
[24F0:2BBC][2018-08-03T21:39:59]e000: Error 0x80070643: Failed to execute MSI package.
[0E68:242C][2018-08-03T21:39:59]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[0E68:242C][2018-08-03T21:39:59]i319: Applied execute package: pms, result: 0x80070643, restart: None
[0E68:242C][2018-08-03T21:39:59]e000: Error 0x80070643: Failed to execute MSI package.
[24F0:2BBC][2018-08-03T21:39:59]i318: Skipped rollback of package: pms, action: Uninstall, already: Absent
[0E68:242C][2018-08-03T21:39:59]i319: Applied rollback package: pms, result: 0x0, restart: None
[24F0:2BBC][2018-08-03T21:39:59]i329: Removed package dependency provider: {82C831F3-71D9-482D-8A82-11B4FF679033}, package: pms
[24F0:2BBC][2018-08-03T21:39:59]i351: Removing cached package: pms, from path: C:\ProgramData\Package Cache\{82C831F3-71D9-482D-8A82-11B4FF679033}v1.13.5291\
[24F0:2BBC][2018-08-03T21:39:59]i351: Removing cached package: vcredist, from path: C:\ProgramData\Package Cache\72211BD2E7DFC91EA7C8FAC549C49C0543BA791B\
[24F0:2BBC][2018-08-03T21:39:59]i326: Removed dependency: {ee1563ba-f9e1-4222-a38b-e88c26fc0f1c} on package provider: {2505AB18-0108-47B3-B335-3FE067556E95}, package pmsshutdown
[24F0:2BBC][2018-08-03T21:39:59]i301: Applying rollback package: pmsshutdown, action: Uninstall, path: (null), arguments: ' ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" INSTALLLOCATION="C:\Program Files (x86)\Plex\Plex Media Server\"'
[0E68:242C][2018-08-03T21:40:00]i319: Applied rollback package: pmsshutdown, result: 0x0, restart: None
[24F0:2BBC][2018-08-03T21:40:00]i329: Removed package dependency provider: {2505AB18-0108-47B3-B335-3FE067556E95}, package: pmsshutdown
[24F0:2BBC][2018-08-03T21:40:00]i351: Removing cached package: pmsshutdown, from path: C:\ProgramData\Package Cache\{2505AB18-0108-47B3-B335-3FE067556E95}v1.13.5291\
[24F0:2BBC][2018-08-03T21:40:00]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ee1563ba-f9e1-4222-a38b-e88c26fc0f1c}, resume: None, restart: None, disable resume: No
[24F0:2BBC][2018-08-03T21:40:00]i330: Removed bundle dependency provider: {ee1563ba-f9e1-4222-a38b-e88c26fc0f1c}
[24F0:2BBC][2018-08-03T21:40:00]i352: Removing cached bundle: {ee1563ba-f9e1-4222-a38b-e88c26fc0f1c}, from path: C:\ProgramData\Package Cache\{ee1563ba-f9e1-4222-a38b-e88c26fc0f1c}\
[24F0:2BBC][2018-08-03T21:40:00]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ee1563ba-f9e1-4222-a38b-e88c26fc0f1c}, resume: None, restart initiated: No, disable resume: No
[0E68:242C][2018-08-03T21:40:00]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
Errors on Win 10 Pro x64 with both PMS and PMP installers for PMP 2.19.1.904-f679df4f and PMS 1.13.8.5395-10d48da0d (or with both prior PMS and PMP installed versions’ installers, PMP 2.17.0.890-7d18e33d and PMS 1.13.6.5339-115f087d6; can’t tell which without significant additional time invested which I don’t intend to do, believing that debugging new releases is a provider, not a customer, responsibility).
Note that both prior version installers worked without error to successfully install PMP and PMS, and continue to do so without incident.
Both installers for the latest builds throw 1714 Error events:
PMP 2.19.1.904-f679df4f: C:\ProgramData\Package Cache{B1952048-C76F-4515-9AEA-F20070C31FF9}v2.17.0\PMP.msi
Event Windows Application Error:
Product: Plex Media Player – Error 1714. The older version of Plex Media Player cannot be removed. Contact your technical support group. System Error 1612.
PMS 1.13.8.5395-10d48da0d: C:\ProgramData\Package Cache{70F01577-23EC-48B1-8998-F7F63FEC9A17}v1.13.6339\pms-shutdown.msi
Product: Stopping Plex – Error 1714. The older version of Stopping Plex cannot be removed. Contact your technical support group. System Error 1612.
Fix for both PMP and PMS is as follows:
- After Plex installer failure, cancel out of the Plex installer.
- Rerun the Plex installer for the prior installed version. It should succeed; if not, this method won’t help.
- Rerun the new build Plex installer. It will fail again.
- Rerun the Plex installer for the prior installed version (yes, again). This time, it should offer a Repair option; select that. The repair install should succeed; if not, this method won’t help.
- Rerun the new build Plex installer. This time, it should succeed; if not, this method won’t help.
The reason I can’t tell whether the fault lies with the new build installer or the old one is that the Repair install for the old one seems to fix the problem with the new build installer, so it’s not possible without much further MSI debugging (as described above) which installer is the source of the scripting error.
Below are sample logs for both new build PMP and PMS installers. They’ve been scrubbed for security purposes (some details are mildly obfuscated).
Hope this helps.
Plex_Media_Player_20180921123935.log (17.4 KB)
Plex Media Server_20180921124214.log (19.7 KB)
Sorry did not get a notification of your post. Is it still an issue ?
There are a number of log files during an install / upgrade and would like to see the whole set.
Please do not paste logs - best to zip and attach the zip as a file
The logs related to the install would have been
Would need to see them all if it is still failing. Or later set of the logs. They have similar names with different date/time suffixes in the filenames
Most issues of this nature are caused by running some cleaning tools such ccCleaner which may remove Package Cache files for installed software. This would stop the upgrades as the method uised is to go through an uninstall and then install and the uninstall needs the cache files which would be in C:\ProgramData\Package Cache
The logs you provided just give the high level error. Could you see if you have the whole set - please zip and attach
C:\Users\%adminuser%\AppData\Local\Temp\Plex_Media_Player_20180921123935.log
C:\Users\%adminuser%\AppData\Local\Temp\Plex_Media_Player_20180921123935_000_pmp.log
C:\Users\%adminuser%\AppData\Local\Temp\Plex_Media_Player_20180921123935_001_vcredist.log
C:\Users\%adminuser%\AppData\Local\Temp\Plex Media Server_20180921124214.log
C:\Users\%adminuser%\AppData\Local\Temp\Plex Media Server_20180921124214_000_pmsshutdown.log
C:\Users\%adminuser%\AppData\Local\Temp\Plex Media Server_20180921124214_001_vcredist.log
C:\Users\%adminuser%\AppData\Local\Temp\Plex Media Server_20180921124214_002_pms.log
