Dedicated port for 2nd server; Remote access failing after success
Server Version#: Windows, Latest
Player Version#: Samsung TV
Hello,
I have port 32500 successfully forwarded to the second server with a dedicated LAN IP. When I click ‘Retry’ it connects successfully. When I log in at plex.tv I see both servers, but I have not tested this from the WAN. The connection is not stable. Whenever I return to that machine I find the Remote Access has turned red.
My friend in Florida is using Plex on a Samsung TV, and she is getting streams from the 1st Linux server (Ubuntu 18.04) but not the 2nd Windows 7 server. The 2nd server has been shared, but is not visible to her.
(Yes, I have searched the forums already, and read the KB articles. I have done the setup correctly.)
TIA
check how the port forward is done for the 2nd server
Both servers must forward to 32400
So server 2 would be
WAN/Public Port 32500
Forwarded to LAN/Local port 32400 to the local IP of the 2nd server
(Some routers do not allow the WAN and LAN ports to be different in a port forward)
Thanks for the reply. My router indeed does not do that. It returns something like, that port is already in use. So, is there a workaround for this? LAN access is not broken. I can reach the server by LAN IP:32400 address. Would UPnP work?
I would recommend replacing the router with one that allows you to have a different port number for WAN and LAN in a port forward.
There are some advanced methods to overcome this and doing google search will find some - eg this https://stackoverflow.com/questions/11525703/port-forwarding-in-windows
But i do not know if there would be any issues
Thanks for the reply. I’ll have to do without a backup server. The Windows server struggles mightily with my music library anyway. The Linux server is fast and stable.
Have a good night!
(Having two servers with overlapping content sounds like a pain to me.)
It’s worth trying with UPnP. Sometimes a router’s GUI won’t let you create two mappings that use the same internal port, but UPnP can.
I think you would want to remove any manual mappings already on the router, so both can be created with UPnP.
As far as I can tell, Plex sends UPnP requests whether it’s configured to pick a port automatically or to use a specific one. I have a specific port configured in Plex, and am using UPnP successfully.
Thanks for the suggestion. I have had 32400 configured to server 1 for a long while now, and it’s working. It’s being used remotely so I’ll just leave it alone, rather than risk breaking it.
:slight_smile: Fair enough.
