Is there anyway to remove (or disable) the recommended tab, so that when a user selects a Library, they go straight to the Library tab?
(when i phrase it like that it actually doesn’t make sense that by default one is brought to the Recommended tab, when they click a Library).
Ie you click Library TV Shows, and you see all of the TV shows.
Is this possible? (ideally on the server side, as ive had a few friends who are confused as to why they cant find all of my large content library).
thanks
There should be an option in the settings to remember the selected tab which will remember the last tab that you selected. It’s a per client setting and not server side.
Are you saying when someone is using a client, they can’t select “Library”? With only showing the “Recommended” they cannot see all of the available shows? That’s the problem I’m having when using my tablet or phone. I have Recommended and much rather chose the show I want at any given time, but Plex ignores when I click on Library and jumps back to Recommended.
He is saying every client has this option (which I thought was defaulted to on/enabled) so when you open a library whichever tab ( Recommended, Library, Collections, Playlists) you were on the last time you were in that library will be the one it returns to when you go back into that library.
