In the chrome web view and firetv players, the defaults are recommended views. Even though I have all recommended un-checked.
Is there anyway to default to the library view instead? I also have plex pass if that matters.
Thanks.
Thanks.
You cannot disable the recommended tab. However you can configure most apps to remember the selected tab in which case they’ll default to the previously used tab when you next access that library.
See: Settings > Experience > Remember selected tab
Thank you - I will try that. Although I believe that is already set.
Strange that Plex doesn’t allow you configure that.
