Deleted DVR Recording Still In Guide
Server Version#: 1.32.0.6973
Player Version#: Browser 4.100.1
Tuner Make/Model: HDHomeRun Prime
Guide/Lineup name: Xfinity Frederick County
Using XMLTV?: no
Channel number/Name: 844 MASNHD
Plex Media Server Logs_2023-04-26_04-46-41.zip (5.5 MB)
I had a recurring recording setup. It was the only recording that I had setup. I deleted the recording via Plex → Live TV → DVR Schedule. It was removed from the daily schedule as expected.
When I go into the Live TV Guide and go to the show that had the recurring recording set up, it still shows that it has a recording scheduled. If I click on the Recording Scheduled item to change the recording, Plex returns “Something Went Wrong An unexpected error occurred.” and I am unable to updated or delete the recording from the guide for that show.
I have restarted the Plex application, rescanned the channels and guide, removed the tuner and readded it. The recurring recording in the Guide for that show is always there and cannot be edited or removed. It will not show up in the DVR Schedule.
A follow up on this issue. After the recordings were aged out of the Guide, I was able to setup recordings for the show that was stuck previously. It is a reproducible issue and happens every time a a recurring recording is deleted via Plex → Live TV → DVR Schedule versus deleting it directly from the Guide.
Did you setup the required separate Libraries, one for TV, one for Movies? Recommend that you make new directories not associated with your others.
