No recordings since 2/5 . Empty DVR schedule
Server Version#: 1.41.4.9463
Player Version#: 1.108.1.307-dd5b87aa
Tuner Make/Model: HD Homerun Flex 4K
Guide/Lineup name: no name is listed
Using XMLTV?: No
Channel number/Name: All
I haven’t had a single recording fire up since 2/5 . Plex says there is no upcoming airing for any of my shows on any channel. I know that is very wrong.
I think what might have triggered this is the deletion/recreation of my TV shows library. However, when I look at the program setup, they all point to the correct library.
So, I’m just not sure why there is nothing scheduled. I have a lifetime Plex pass. I have not changed the lineup or tuner in any way. How do I fix this ?
If you haven’t already, try deleting and recreating the scheduled recording for a show which you know has upcoming airings. Make sure you set it to record all episodes, and new and repeat airings.
With those settings, the only thing which would prevent it from recording is if it were already in one of your libraries. (It will not record duplicates.)
