deleted
deleted
Seriously. Your first post was about 15 hours ago.
Just because the “Unanswered” list has hundreds of threads doesn’t mean they are all unanswered. Many are there because nobody marked them as answered.
Plex certainly has a long way to go to fix their poor customer support record, but geez, 15 hours? Get in line.
Your one question is also not in the right place as it concerns Roku with a Mac server and you posted in the Linux forum. If you post in the Roku forum you’ll likely to get an answer as the developer is very active to support users.
thanks i’m new here (duh) didn’t see that I did that.
i appreciate that. yes i am expecting a lot i guess. just seemed like my questions should have been easy to find answers to and after searching others similar that were not answered its hard to believe the forums work. but i reposted my question in the proper place. we’ll see.
patience is indeed a virtue. we all want on demand customer service, but it’s honestly not realistic all of the time. hopefully now that your question has been placed in the proper place it will get resolved. i wish you the best (and me too) :slight_smile:
@charidea said:
seriously. hundreds of unanswered questions. including mine. I am ready to bolt. anyone want to suggest an alternative?
Probably your issue is fixed in the latest update.
Just another day…
The 4.3.0 update has been published to the official channel.
NEW:
Support for SD UI resolution
Support for 1080p UI resolution (Roku 4, Roku 4k TV, Premiere, Premiere+ and Ultra)
Photo Tags (related photos in photo player)
Roku Ultra: Add support to Direct Play video containing 5.1 AAC audio
Roku Ultra: Add support to transcode unsupported audio streams to AAC 5.1
Use HLS/AAC for transcoded music instead of mp3 (better quality, better seeking)
Improve subtitle visibility when background opacity is off
Move subtitles in view when the OSD is visible
Display disc number for multi-disc albums
FIXES:
Improve channel startup time
Improve preplay loading time
Improve image quality
Improve performance moving between preplays (FWD/RWD buttons)
Improve Plex Cloud playback
Disable Post Play Auto Play after manually stopping playback
Misleading verbiage after video playback failure
Do not offer Plex Pass purchase options to Plex Home users
Improve flyout info for unreachable and unauthorized servers
Update Cinema Trailer options (pre-roll only option)
Duplicate key presses using universal remotes
Refresh Play Queue after toggling repeat mode
Photo player OSD shuffle status
Better failure messages during photo player failures
Include artist, album, and artwork for all playlist tracks
Disable Direct Play for mpeg4/xvid
Resuming video after changing video settings in the OSD
Better handle copying video streams when frame rate is higher than 30fps
Retain video playback settings during continuous play
Better handle HLS fallback on MKV transcode failures
Prefer MKV transcode format for HEVC/VP9 content
Always attempt direct play for HLS streams
Crash during continuous play using Roku HD/LT
Improve indications when media is unavailable
Verify media is accessible before playback, for multi-media content
Fix a few rare crashes
