Deleted
Ive found that if you dont include the proper year when fixing the match it wont return what you are looking for, the other trick is to use “Great Cars: The Television Series tvdb-351086” and the year as 2003 and see if that gets you what you are looking for
Make sure you’re using the right agent. Sounds like you’re matching using TMDB and not TheTVDB.
There’s strange-ish data coming from Plex for the show. There’s only one Plex show entry, linked to both the 2003 and 2018 entries at TVDB. I dunno how that can work.
guid="plex://show/606ee603577d5e002c384de1"
<Guid id="imdb://tt0874557"/>
<Guid id="tmdb://44391"/>
<Guid id="tvdb://170681"/>
<Guid id="tvdb://351086"/>
I think Plex needs to split these apart. You’ll never be able to match it differently since Plex only has one smushed-together entry.
I wonder if it was only recently split apart at TVDB.
I notice that TVDB doesn’t have any “On Other Sites” info for 170681, and I can’t find it on TMDB either.
