Deleting a recording does not refresh library
I am using the Plex client on nvidia shield. For the longest time across multiple versions of Plex I run into the following bug:
In library view I select a show or movie (film) and then select ‘more’ followed by ‘delete’.
Result: While the recording will be deleted, the show/movie cover is still being displayed. I must exit this view and e.g. select home, go back and then it’s gone.
I would appreciate if this could be fixed
Do you see the same behavior when watching a show? (It remains “Unwatched” until you refresh the view)
No, watching a show is being updated correctly
I am seeing the same behavior with my Nvidia Shield TV. It used to be that when I deleted a show from the app the library would instantly reflect that deletion, removing the show from the library. Now the the library still displays the show, but I can make it go away by forcing a scan of the library, switching to a different library, and then switching back to my TV Shows library. This is annoying and definitely wasn’t happening in the past (as recently as a few weeks ago).
