Den nye EPG
Hej
Vil bare lige checke om nedenstående problemer med den nye EPG er generelle, eller kun rammer mig:
(jeg har YouSee kabel TV)
  1. DRK mangler. Kanal 21 (som burde være DRK) findes som DR3HD, der har samme indhold som kanal 20 DR3
  2. Opdatering er meget sen eller fraværendende. Fx her lørdag aften, kan jeg ikke se TV programmet for næste uge.
Tak
Thanks for sending in the feedback form
The issue with 21 DRK should be fixed now. To pick the right channel please go through delete DVR and a few minutes later recreate it. Alternatively, you should be able to pick the right channel numbers by clicking on Scan Channels on DVR Server settings
Thanks. No need to delete and re-install the DVR. Just enabling the channel in the DVR settings did the trick. Thanks for speedy and effective resolution.
