When setting Live TV & DVR I can't change EPG Channels to the correct call sign
I pick up channels in different zip codes that I can enter in. I then scan for channels and they show up, but when i click on the down arrow to put the right call sign on them it won’t change to the right call sign. so I’m back to missing half my channels again. anybody have any ideas ?
I am also experiencing this issue. Seems to have begun in a recent update. Here is another thread.
Same here, some channels have the same number and I cannot select the correct option (only the first one)
Example for UK
Skyq or skySD channel 102 ‘BBC radio 2’ or ‘BBC 2’ I try to set the second option of BBC2 but it will not select and it will only select BBC2 radio.
Are there any previous docker images so I can roll back ?
