Description and cover Picture in wrong language
Server Version#: 1.28.1.6104
Player Version#: Version 4.89.1
I got a problem with my Meta Loading. My Libary my server everthing is set to german. But some Videos which I have get english Descriptions and cover pictures.
I looked everywhere for a solution but found none.
Funny at the whole thing is…If i try to change the assignment I see in the search result the correct cover with the german description. If I click on it. It stays english.
These settings are irrelevant for the new agents.
All agent-related settings are now found in the properties of your library, on the “Advanced” tab.
  1. verify that the library language has been set to German
  2. make sure that you are not overwriting Plex metadata with information which is embedded in your files. Verify that “Prefer local metadata” is not activated.
  3. Edit the movie in question. On the Advanced tab there is a selector which allows you to override the metadata language just for this movie. Is it set to anything else than “library default”?
Yeah read that just now somewhere else so I editited it out.
  1. https://i.imgur.com/9HkbmCJ.png Its German.
  2. https://i.imgur.com/dKNuUAo.png Its not set.
  3. https://i.imgur.com/K5nMYFm.png Its not set to Mediathek standard but its german.
I deleted now my Libary created it new and the problem persists.
Everything is set to german I see german search results but if I click on the correct search result he saves the english result (which is not shown in the results) to the film.
Please show me the first ~20 lines of the Plex media info XML of that movie.
I send you the xml per PM
The german metadata were only added 2 days ago on TMDB: Women (2021) - Changes — The Movie Database (TMDB)
Please allow 48 hours for changes to get available in Plex, as they often have a delay before they a) get available via the API of TMDB and b) get synced to the Plex metadata servers.
Ahhhh thanks
