Hi, I found when moving subtitles synchro plus or minus, there is error in Debug
23:21:42 T:3045892096 ERROR: unable to load:/usr/share/xbmc/addons/skin.plex/720p/DialogSlider.xml, Line 0
23:21:44 T:3045892096 DEBUG: ------ Window Deinit (DialogSlider.xml) ------
the file is not in the skin so it's not visible how much u moved your subtitles by...
Can you put it back or there is a performance issue?
atrus
2
This should only happen if you are using another language than English in PHT. Is that true for you?
