Hi
So I have a movie which has given me a problem I’ve never encountered before despite despite that I’ve had at least 600 movies and a lot of series.
On my Shield TV I have perfect sound but the image is frozen. When I jump forward in the movie it generates the correct frame but that’s it. Sound is still ok but the picture is frozen.
According to the dashboard it direct steams both video and sound.
On firefox web the video works perfectly but the sound stutters a lot. It’s like you only hear a fraction of a second long snippets of the sound, several times per second.
Video is direct stream but sound is transcoded to aac from eac3 5.1
On Plex on my iPhone both sound and video works fine.
It direct plays both sound and video.
So the movie works on one device and it fails in two different ways on two other devices.
Can anyone pinpoint the problem? Is there an easy fix?
Server version: 1.20.3.3483
Player version: Latest on Shield (updated yesterday), my phone just died so I can’t check but it’s the latest or second to latest.
The video file:
Format : Matroska
Format version : Version 4
File size : 21.4 GiB
Duration : 2 h 36 min
Overall bit rate : 19.6 Mb/s
Encoded date : UTC 2020-08-15 06:13:45
Writing application : mkvmerge v49.0.0 (‘Sick Of Losing Soulmates’) 64-bit
Writing library : libebml v1.4.0 + libmatroska v1.6.1
Video
Format : AVC
Format profile : High@L5
Format settings : CABAC / 12 Ref Frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 17.9 Mb/s
Width : 1 920 pixels
Height : 804 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.484
Stream size : 19.5 GiB (91%)
Writing library : x264 core 160 r3009 4c9b076
Default : Yes
Forced : No
Audio #1
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 1 080 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 62.500 FPS (768 SPF)
Compression mode : Lossy
Stream size : 1.18 GiB (6%)
Language : Korean
Service kind : Complete Main
Default : Yes
Forced : No
Edit: Maybe I should say that the file plays fine on my pc and mac using vlc.
