Difficulty adding show with more than 100 seasons
Server Version#: 1.32.3.7089
Hoping someone can help me out here. I’ve been adding House Hunters to Plex, and everything has been going great. Seasons 1-99 added without a problem. However, starting with Season 100, they are not adding properly to Plex. If I browse to the folder in the show on Plex under TV Shows → Folders, it sees the Season 100 folder, but if you click it it says ‘Empty Folder’
Here is the structure that is working for Plex:
T:\TV Shows\House Hunters\Season 99\House Hunters - 99x01 - Twenty-Something Wants Fixer Upper in Illinois
Here is the structure that is not working:
T:\TV Shows\House Hunters\Season 100\House Hunters - 100x01 - New Jersey Couple Wants Southern Charm in Georgia
I assume its related to the three digit season number, but how can I work around this?
Plex dance the episode and try using House Hunters - s100e01 - New Jersey Couple Wants Southern Charm in Georgia
100x01 is not the recommended naming and while it may work sometimes it’ll only work until it doesn’t → https://support.plex.tv/articles/naming-and-organizing-your-tv-show-files
I’ll give this a try.
Edit: What @dokuro suggested worked, Plex dance + explicitly naming it with SxxxExx worked.
If you use the TVDB show order you can use this if you don’t already have a renaming program
