Direct Play Problem over the internet (If I connect the server side over VPN, Direct connection works well)
Hello,
My system runs over “TS-h886-D1622-16G Intel® Xeon® D-1622 4 cores/8 threads 2.6 GHz processor (Turbo Boost up to 3.2 GHz), 16 GB DDR4 ECC memory (2 x 8 GB)”.
My server runs in a data center. My connection is 1GB for Download and 1GB for upload. Moreover, my connection in my home is 100MB download and 10mb Upload.
When I tried to watch any video as direct play, the plex doesn’t allow me to use direct play. On the other hand, when I connect to the Qnap device where the plex server runs, over VPN connection, Direct play works well.
I already control the settings many time every things set correctly.
I do not understant How direct play doesn’t active on standart connection, and How direct play active on VPN connection.
Please help me!!!
Not sure if you are using some particular app but if it is transcoding then I would look at the playback info in the app while it is playing to see what it says about transcode reason. or look at server logs to see the media decision when playback started.
BigWheel Thank you very much for suppğrt and guidance. we will check and come back ASAP.
Hi BigWheel,
Please find enclosed Zip file for our LOGs.
Plex Media Server Logs_2021-11-12_09-46-37.zip (5.7 MB)
Thanks in advance
Might be related to the fact the once a VPN is established, the “connection” to the Plex seems to originate from a LOCAL LAN IP or something ? That might impact certain decisions…
(Settings → Network)
LAN Networks
X.X.X.X/Y
Comma separated list of IP addresses or IP/netmask entries for networks that will be considered to be on the local network when enforcing bandwidth restrictions. If set, all other IP addresses will be considered to be on the external network and will be subject to external network bandwidth restrictions. If left blank, only the server’s subnet is considered to be on the local network.
What is the remote quality set to in the app? and do you have auto quality enabled in the app you are using for playback? Looks like it is transcoding a video to 720p which is the default remote streaming quality.
Hi, jvanhambelgium,
When we connected to the system over VPN, our device will be like local device. However under this circumstances the other setting related with the internet connection has been done as it is described.
Remote Streaming is Maximum on the application. We also tried auto quality enabled or disabled. we tried both version and the result is same.
Moreover, we have tried over iphone, ipad, Apple TV, MAc PC and Windows pc as a client. we done all the setting for Direct streaming. however the result is always same.
Hi BigWheel,
Do you a chance to review Log files. and do you have any other suggestion. I really like Plex. but I couldn’t watch original videos.
