Hello.
Is there a way for plex to default to users selection when first login to device? When I login on a new device it is always defaulting to my user which is the first user.
Thanks.
Hello.
Thanks.
Hi, you can go into settings and disable Automatically Sign In
This won’t achieve anything. Because the login is done with the access credentials of the Plex Home owner (i.e. the server administrator)
If you give these credentials out of your hands, you have already lost.
What client are you using? Some clients do show the user selector after signing in.
