Disable all metadata agents
Is it possible to disable the metadata agents. Mainly i've run into an issue where the TVDB i have these episodes out of order, even if i change it, it'll see to reset it.
Does anyone know if this is possible?
Jeff
I am currently trying to find a way too... some are just grey'd out and appear not to have the option. What I'm currently sitting here doing might work... but not sure if it will for everything... hit up the Media Manager - Scroll down and for Channels select "Show All". You'll see 'My Channels' and 'Directory', click on Directory. Head over to MORE... and then choose Installed Plug-ins. I wasn't able to find imdb, however, I was able to remove every agent for tv shows. I haven't removed and re-added the directory for proof of concept, but I think this will work... ?
----Update----
Seriously? It's required? If there's not an agent, it won't add the directory.... Seriously??
Make a Home Videos section and it will use only the Video Files scanner and Personal Media agent (which uses only embedded and local metadata, it will not hit TheTVDB).
If you remove the default agents from the channel directory, they'll be automatically reinstalled (best case), or cause other unforeseen consequences, so that's not recommended.
