Server Version#: 1.18.2.2058-e67a4e892
Player Version#: No idea
Hey guys,
is there any way to disable the buggy hosted UI?
I moved my PMS to a new machine and every time I open :32400 on the new server, I get the hosted Plex UI. It tries to connect to like 4-5 different, confusing URLs - and even though some work, it still say’s I can’t connect.
I would probably need to change the custom server access URL I had setup and relogin (as I kicked the server out of the account).
While I can open up :32400, it ALWAYS gives me the hosted UI. No way to login.
In some cases, you may find that the Server entry doesn’t appear for you under Settings in the web app and thus you can’t try to sign in to the Server. This often occurs when you’re not yet signed in on the Server and you’re using the hosted Plex Web App.
Load the “bundled version of Plex Web App” on your Server computer using http://localhost:32400/web or http://127.0.0.1:32400/web , for instance
Yes, I have read that article.
The simple fact is, it doesn’t work. There is no local Plex Web App, only the hosted one. And it has been like that on my server for months.
I can’t understand why Plex on the one side has a lot of really cool features - but on the other hand is one of the buggiest software on the planet.
I even just created a new server via Docker AND created a brand new account. Still no way to claim the server, instantly redirects to the hosted UI (while still having the server IP in the search bar).
I feel like 2-3 weeks ago Plex destroyed something…
