Disable partial recordings
Hi
When scheduling a TV recording there is an option in advanced settings to allow partial recordings. This is always enabled (so it allow.s partial recordings). I never want to record part of a movie (I cant imagine why anyone would want to) but I cant see any way of changing this default.
How can I set the default to disable partial recordings?
thanks
warren.
Anybody?
At present, it’s not possible to change the default setting. :slight_smile:
You can’t change the default, but you can disable this on a per-recording or per-show basis. I’ve just trained myself to select this every time I set up a recording. Agree that I can’t imagine why the default is set the way that it is…
