I’ve looked through all of the threads but couldn’t find one specifically related to my issues.
Setup:
Windows 10
ATV3 - 7.2
When I start plexconnect everything starts up fine. When I try to load into Trailers I get trailers unavailable. On the Windows side plexconnect shows this:
09:59:59 PlexConnect: started: 09:59:59
09:59:59 PlexConnect: Version: 0.5-dev-211015
09:59:59 PlexConnect: Python: 2.7 (r27:82525, Jul 4 2010, 07:43:08) [MSC v.1500 64 bit (AMD64)]
09:59:59 PlexConnect: Host OS: win32
09:59:59 PlexConnect: PILBackgrounds: Is PIL installed? False
09:59:59 PlexConnect: IP_self: 192.168.11.128
09:59:59 DNSServer: started: 09:59:59
09:59:59 DNSServer: ***
09:59:59 DNSServer: DNSServer: Serving DNS on 192.168.11.128 port 53.
10:00:00 WebServer: started: 10:00:00
10:00:00 WebServer: ***
10:00:00 WebServer: WebServer: Serving HTTP on 192.168.11.128 port 80.
10:00:00 WebServer: WebServer: Serving HTTPS on 192.168.11.128 port 443.
If I set my Windows machine to use itselfs as DNS I start seeing responses in the plexconnect window. I however never see anything come across for my ATV3. I would assume this means that something is blocking port 53. My firewall is turned off on private networks which my computer is set to. Not sure how to find the issue. Any help would be greatly appreciated.
