DNS problems, port 53. Setting up ATV with plex
Trying to set up Plex with a Mac running OSX 10.9.4 and Apple TV 3
Following the guide found here: https://www.youtube.com/watch?v=IeYlb9aCuC8
When I run the  sudo ./PlexConnect.py command, I get "Failed to create socket on UDP port 53: [Errno 48] Address already in use"
Did some searching on here and found nothing that solved my issue thus far...
Whats interesting though, Trailers app on the ATV opens to pled and I'm able to watch my content. It says that trailers are not available if I try to play something from the channels tab in plex..
Any help?
Heres what Im getting in terminal....
Bills-Mac-mini:~ wwohl$ cd /Users/wwohl/Desktop/PlexConnect-master
Bills-Mac-mini:PlexConnect-master wwohl$ sudo ./PlexConnect.py
17:17:38 PlexConnect: ***
17:17:38 PlexConnect: PlexConnect
17:17:38 PlexConnect: Press CTRL-C to shut down.
17:17:38 PlexConnect: started: 17:17:38
17:17:38 PlexConnect: Version: 0.4+
17:17:38 PlexConnect: Python: 2.7.5 (default, Mar  9 2014, 22:15:05)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
17:17:38 PlexConnect: Host OS: darwin
17:17:38 PlexConnect: IP_self: 192.168.1.3
17:17:38 DNSServer: started: 17:17:38
17:17:38 DNSServer: Failed to create socket on UDP port 53: [Errno 48] Address already in use
17:17:38 PlexConnect: DNSServer not alive. Shutting down.
17:17:38 PlexConnect: Shutting down.
17:17:38 PlexConnect: shutdown
Bill
edit: ran the following command : sudo lsof -i -P
COMMAND    PID           USER   FD   TYPE             DEVICE SIZE/OFF   NODE NAME
launchd      1           root   18u  IPv4 0x7b77578d4bb088c1      0t0    UDP *:137
launchd      1           root   19u  IPv4 0x7b77578d4bb086d9      0t0    UDP *:138
launchd      1           root   25u  IPv6 0x7b77578d4bfe9881      0t0    TCP localhost:631 (LISTEN)
launchd      1           root   26u  IPv4 0x7b77578d4bfea889      0t0    TCP localhost:631 (LISTEN)
UserEvent   11           root    5u  IPv4 0x7b77578d4c8c18c1      0t0    UDP *:*
UserEvent   11           root    9u  IPv4 0x7b77578d4bb075b1      0t0    UDP *:*
configd     18           root   16u  IPv6 0x7b77578d4ca2a8c1      0t0 ICMPV6 *:*
mDNSRespo   72 _mdnsresponder    8u  IPv4 0x7b77578d4bb08309      0t0    UDP *:5353
mDNSRespo   72 _mdnsresponder    9u  IPv6 0x7b77578d4bb08121      0t0    UDP *:5353
mDNSRespo   72 _mdnsresponder   25u  IPv6 0x7b77578d60cde981      0t0    UDP *:*
mDNSRespo   72 _mdnsresponder   27u  IPv6 0x7b77578d4d17d6d9      0t0    UDP *:*
mDNSRespo   72 _mdnsresponder   44u  IPv6 0x7b77578d4d18cf39      0t0    UDP *:*
mDNSRespo   72 _mdnsresponder   45u  IPv6 0x7b77578d4d17d309      0t0    UDP *:*
mDNSRespo   72 _mdnsresponder   52u  IPv6 0x7b77578d60d69671      0t0    UDP *:*
mDNSRespo   72 _mdnsresponder   54u  IPv6 0x7b77578d4d18d4f1      0t0    UDP *:*
mDNSRespo   72 _mdnsresponder   60u  IPv6 0x7b77578d60d6a5b1      0t0    UDP *:*
mDNSRespo   72 _mdnsresponder   62u  IPv6 0x7b77578d4d17cf39      0t0    UDP *:*
mDNSRespo   72 _mdnsresponder   68u  IPv6 0x7b77578d60d6ab69      0t0    UDP *:*
mDNSRespo   72 _mdnsresponder   71u  IPv4 0x7b77578d4d18c5b1      0t0    UDP all-systems.mcast.net:5350
mDNSRespo   72 _mdnsresponder   72u  IPv6 0x7b77578d4bb06ff9      0t0    UDP *:*
mDNSRespo   72 _mdnsresponder   85u  IPv4 0x7b77578d60d6b6d9      0t0    UDP *:49939
mDNSRespo   72 _mdnsresponder   86u  IPv6 0x7b77578d4d18d6d9      0t0    UDP *:49939
mDNSRespo   72 _mdnsresponder   87u  IPv4 0x7b77578d60d68b01      0t0    UDP *:55855
mDNSRespo   72 _mdnsresponder   88u  IPv6 0x7b77578d60cddff9      0t0    UDP *:55855
mDNSRespo   72 _mdnsresponder   89u  IPv4 0x7b77578d4d18c3c9      0t0    UDP *:60736
mDNSRespo   72 _mdnsresponder   90u  IPv6 0x7b77578d4bb06c29      0t0    UDP *:60736
locationd   77     _locationd    5u  IPv4 0x7b77578d4c8bece9      0t0    UDP *:*
blued       91           root    4u  IPv4 0x7b77578d4c8bf2a1      0t0    UDP *:*
apsd        95           root   13u  IPv4 0x7b77578d5e8510a1      0t0    TCP bills-mac-mini:58762->17.172.232.196:5223 (ESTABLISHED)
apsd        95           root   15u  IPv4 0x7b77578d5e8510a1      0t0    TCP bills-mac-mini:58762->17.172.232.196:5223 (ESTABLISHED)
airportd    97           root   10u  IPv6 0x7b77578d4bb060b9      0t0    UDP *:*
airportd    97           root   21u  IPv4 0x7b77578d4c8c16d9      0t0    UDP *:*
airportd    97           root   22u  IPv4 0x7b77578d4c8c14f1      0t0    UDP *:*
airportd    97           root   25u  IPv4 0x7b77578d4c8bfc29      0t0    UDP *:*
airportd    97           root   26u  IPv4 0x7b77578d4c8bfa41      0t0    UDP *:*
airportd    97           root   29u  IPv4 0x7b77578d4c8bf859      0t0    UDP *:*
airportd    97           root   31u  IPv4 0x7b77578d4c8bf671      0t0    UDP *:*
SophosSXL  100           root    7u  IPv4 0x7b77578d4bb084f1      0t0    UDP *:58293
SophosSXL  100           root    8u  IPv4 0x7b77578d4bb07f39      0t0    UDP localhost:55628
InterChec  103           root   61u  IPv4 0x7b77578d546f44f1      0t0    UDP *:49685
ntpd       216           root   20u  IPv4 0x7b77578d4d18d309      0t0    UDP *:123
ntpd       216           root   21u  IPv6 0x7b77578d4d18d121      0t0    UDP *:123
ntpd       216           root   22u  IPv6 0x7b77578d4d18cd51      0t0    UDP localhost:123
ntpd       216           root   23u  IPv4 0x7b77578d4d18cb69      0t0    UDP localhost:123
ntpd       216           root   24u  IPv6 0x7b77578d4d18c981      0t0    UDP localhost:123
ntpd       216           root   25u  IPv6 0x7b77578d60d84309      0t0    UDP bills-mac-mini.local:123
ntpd       216           root   26u  IPv4 0x7b77578d60d7ace9      0t0    UDP bills-mac-mini:123
UserEvent  272          wwohl    6u  IPv4 0x7b77578d4c8c1309      0t0    UDP *:*
SystemUIS  280          wwohl   12u  IPv4 0x7b77578d4c8c0b69      0t0    UDP *:*
Finder     281          wwohl    5u  IPv4 0x7b77578d4db65889      0t0    TCP localhost:54913->localhost:26164 (ESTABLISHED)
Finder     281          wwohl    6u  IPv4 0x7b77578d4db65889      0t0    TCP localhost:54913->localhost:26164 (ESTABLISHED)
sharingd   316          wwohl   22u  IPv4 0x7b77578d4cdf98c1      0t0    UDP *:*
SpotifyWe  366          wwohl    6u  IPv4 0x7b77578d51224889      0t0    TCP localhost:4370 (LISTEN)
SpotifyWe  366          wwohl    7u  IPv4 0x7b77578d512240a1      0t0    TCP localhost:4380 (LISTEN)
Dropbox    371          wwohl   20u  IPv4 0x7b77578d4def40a1      0t0    TCP localhost:26164->localhost:54913 (ESTABLISHED)
Dropbox    371          wwohl   21u  IPv4 0x7b77578d546e8889      0t0    TCP 192.168.1.110:51217->10.0.0.1:443 (CLOSED)
Dropbox    371          wwohl   22u  IPv4 0x7b77578d5e5fe889      0t0    TCP bills-mac-mini:58760->sjd-rf15-3b.sjc.dropbox.com:80 (ESTABLISHED)
Dropbox    371          wwohl   25u  IPv4 0x7b77578d4cdf9309      0t0    UDP *:17500
Dropbox    371          wwohl   28u  IPv4 0x7b77578d53119889      0t0    TCP *:17500 (LISTEN)
Dropbox    371          wwohl   34u  IPv4 0x7b77578d54069889      0t0    TCP localhost:26164 (LISTEN)
iTunes     374          wwohl   20u  IPv4 0x7b77578d518b20a1      0t0    TCP *:49187 (LISTEN)
iTunes     374          wwohl   22u  IPv4 0x7b77578d51ce6889      0t0    TCP *:3689 (LISTEN)
iTunes     374          wwohl   27u  IPv6 0x7b77578d4bfe9441      0t0    TCP *:3689 (LISTEN)
iTunes     374          wwohl   44u  IPv6 0x7b77578d51e94681      0t0    TCP bills-mac-mini.local:3689->atv-plex.local:50650 (ESTABLISHED)
iTunes     374          wwohl   45u  IPv6 0x7b77578d51e96881      0t0    TCP bills-mac-mini.local:3689->[fe80:4::107c:ddad:bc11:94fd]:49372 (ESTABLISHED)
iTunes     374          wwohl   46u  IPv6 0x7b77578d4ff5d001      0t0    TCP bills-mac-mini.local:3689->atv-plex.local:50344 (ESTABLISHED)
iTunes     374          wwohl   47u  IPv6 0x7b77578d4ec86341      0t0    TCP bills-mac-mini.local:3689->atv-plex.local:50349 (ESTABLISHED)
iTunes     374          wwohl   48u  IPv6 0x7b77578d51e95781      0t0    TCP bills-mac-mini.local:3689->atv-plex.local:50350 (ESTABLISHED)
iTunes     374          wwohl   49u  IPv4 0x7b77578d5a86d0a1      0t0    TCP bills-mac-mini:3689->192.168.1.2:49287 (ESTABLISHED)
iTunes     374          wwohl   56u  IPv4 0x7b77578d523450a1      0t0    TCP bills-mac-mini:59271->a23-209-67-120.deploy.static.akamaitechnologies.com:443 (ESTABLISHED)
iTunes     374          wwohl   62u  IPv4 0x7b77578d523450a1      0t0    TCP bills-mac-mini:59271->a23-209-67-120.deploy.static.akamaitechnologies.com:443 (ESTABLISHED)
iTunes     374          wwohl   65u  IPv4 0x7b77578d5246b0a1      0t0    TCP bills-mac-mini:59272->a23-209-67-120.deploy.static.akamaitechnologies.com:443 (ESTABLISHED)
iTunes     374          wwohl   69u  IPv4 0x7b77578d5246b0a1      0t0    TCP bills-mac-mini:59272->a23-209-67-120.deploy.static.akamaitechnologies.com:443 (ESTABLISHED)
Mail       376          wwohl   39u  IPv4 0x7b77578d5e391889      0t0    TCP bills-mac-mini:58787->17.172.34.90:993 (ESTABLISHED)
Mail       376          wwohl   43u  IPv4 0x7b77578d544ea0a1      0t0    TCP bills-mac-mini:58771->qg-in-f108.1e100.net:993 (ESTABLISHED)
Mail       376          wwohl   48u  IPv4 0x7b77578d5e391889      0t0    TCP bills-mac-mini:58787->17.172.34.90:993 (ESTABLISHED)
Mail       376          wwohl   53u  IPv4 0x7b77578d5d907889      0t0    TCP bills-mac-mini:58766->imap-old.mail.me.com:993 (ESTABLISHED)
Mail       376          wwohl   55u  IPv4 0x7b77578d5e75e889      0t0    TCP bills-mac-mini:58767->qg-in-f109.1e100.net:993 (ESTABLISHED)
Mail       376          wwohl   56u  IPv4 0x7b77578d58f2b889      0t0    TCP bills-mac-mini:58772->qg-in-f108.1e100.net:993 (ESTABLISHED)
Mail       376          wwohl   57u  IPv4 0x7b77578d5e75e889      0t0    TCP bills-mac-mini:58767->qg-in-f109.1e100.net:993 (ESTABLISHED)
Mail       376          wwohl   58u  IPv4 0x7b77578d5e6eb0a1      0t0    TCP bills-mac-mini:58791->17.172.34.14:993 (ESTABLISHED)
Mail       376          wwohl   59u  IPv4 0x7b77578d5d907889      0t0    TCP bills-mac-mini:58766->imap-old.mail.me.com:993 (ESTABLISHED)
Mail       376          wwohl   60u  IPv4 0x7b77578d544ea0a1      0t0    TCP bills-mac-mini:58771->qg-in-f108.1e100.net:993 (ESTABLISHED)
Mail       376          wwohl   61u  IPv4 0x7b77578d58f2b889      0t0    TCP bills-mac-mini:58772->qg-in-f108.1e100.net:993 (ESTABLISHED)
Mail       376          wwohl   62u  IPv4 0x7b77578d5d4a80a1      0t0    TCP bills-mac-mini:58773->qg-in-f109.1e100.net:993 (ESTABLISHED)
Mail       376          wwohl   64u  IPv4 0x7b77578d5d4a80a1      0t0    TCP bills-mac-mini:58773->qg-in-f109.1e100.net:993 (ESTABLISHED)
Mail       376          wwohl   65u  IPv4 0x7b77578d59d91889      0t0    TCP bills-mac-mini:58774->17.172.34.45:993 (ESTABLISHED)
Mail       376          wwohl   66u  IPv4 0x7b77578d5e6eb0a1      0t0    TCP bills-mac-mini:58791->17.172.34.14:993 (ESTABLISHED)
Mail       376          wwohl   67u  IPv4 0x7b77578d59d91889      0t0    TCP bills-mac-mini:58774->17.172.34.45:993 (ESTABLISHED)
Google     379          wwohl   35u  IPv4 0x7b77578d545090a1      0t0    TCP localhost:37483 (LISTEN)
Google     379          wwohl   37u  IPv4 0x7b77578d518b2889      0t0    TCP *:* (CLOSED)
Google     379          wwohl   46u  IPv4 0x7b77578d546e80a1      0t0    TCP bills-mac-mini:49244->64.233.171.95:443 (CLOSE_WAIT)
Google     379          wwohl   55u  IPv4 0x7b77578d546c60a1      0t0    TCP bills-mac-mini:49238->64.233.171.84:443 (CLOSE_WAIT)
Google     379          wwohl   56u  IPv4 0x7b77578d51f02889      0t0    TCP *:* (CLOSED)
Google     379          wwohl   57u  IPv4 0x7b77578d53851889      0t0    TCP *:* (CLOSED)
Google     379          wwohl   58u  IPv4 0x7b77578d597fa889      0t0    TCP *:* (CLOSED)
Google     379          wwohl   59u  IPv4 0x7b77578d4e2a90a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   60u  IPv4 0x7b77578d589cd0a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   61u  IPv4 0x7b77578d4db650a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   62u  IPv4 0x7b77578d51ce60a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   63u  IPv4 0x7b77578d597fa0a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   64u  IPv4 0x7b77578d4e2a9889      0t0    TCP *:* (CLOSED)
Google     379          wwohl   65u  IPv4 0x7b77578d4f52d889      0t0    TCP *:* (CLOSED)
Google     379          wwohl   67u  IPv4 0x7b77578d612d90a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   68u  IPv4 0x7b77578d6130a0a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   69u  IPv4 0x7b77578d61329889      0t0    TCP *:* (CLOSED)
Google     379          wwohl   70u  IPv4 0x7b77578d612ef0a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   71u  IPv4 0x7b77578d54e4e889      0t0    TCP *:* (CLOSED)
Google     379          wwohl   72u  IPv4 0x7b77578d54e4e0a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   73u  IPv4 0x7b77578d537550a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   74u  IPv4 0x7b77578d540690a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   75u  IPv4 0x7b77578d612d9889      0t0    TCP *:* (CLOSED)
Google     379          wwohl   76u  IPv4 0x7b77578d612820a1      0t0    TCP *:* (CLOSED)
Google     379          wwohl   78u  IPv4 0x7b77578d4d883889      0t0    TCP bills-mac-mini:54633->qa-in-f125.1e100.net:5222 (ESTABLISHED)
Google     379          wwohl   83u  IPv4 0x7b77578d613d0889      0t0    TCP *:* (CLOSED)
Spotify   1760          wwohl    7u  IPv4 0x7b77578d544ea889      0t0    TCP localhost:4381 (LISTEN)
Spotify   1760          wwohl    8u  IPv4 0x7b77578d53755889      0t0    TCP localhost:4371 (LISTEN)
Spotify   1760          wwohl   36u  IPv4 0x7b77578d538510a1      0t0    TCP localhost:8099 (LISTEN)
Spotify   1760          wwohl   40u  IPv4 0x7b77578d60d7aed1      0t0    UDP *:57621
Spotify   1760          wwohl   43u  IPv4 0x7b77578d57caa0a1      0t0    TCP *:57621 (LISTEN)
Spotify   1760          wwohl   77u  IPv4 0x7b77578d5e5f90a1      0t0    TCP bills-mac-mini:58761->ash1-accesspoint-a12.ash1.spotify.com:80 (ESTABLISHED)
Python    3000           root    4u  IPv4 0x7b77578d4d18bc29      0t0    UDP bills-mac-mini:53
Python    3000           root    7u  IPv4 0x7b77578d4d17cd51      0t0    UDP *:64645
Python    3001           root    4u  IPv4 0x7b77578d59a7a0a1      0t0    TCP bills-mac-mini:80 (LISTEN)
Python    3002           root    4u  IPv4 0x7b77578d59878889      0t0    TCP bills-mac-mini:443 (LISTEN)
Plex\x20M 3475          wwohl   59u  IPv4 0x7b77578d532ff889      0t0    TCP *:32400 (LISTEN)
Plex\x20M 3475          wwohl   60u  IPv4 0x7b77578d532fa889      0t0    TCP *:32401 (LISTEN)
Plex\x20M 3475          wwohl   69u  IPv4 0x7b77578d4cdf6ce9      0t0    UDP *:32413
Plex\x20M 3475          wwohl   84u  IPv4 0x7b77578d4d17d121      0t0    UDP *:32414
Plex\x20M 3475          wwohl   85u  IPv4 0x7b77578d60cde1e1      0t0    UDP localhost:59699
Plex\x20M 3475          wwohl   86u  IPv4 0x7b77578d4c8c01e1      0t0    UDP *:32410
Plex\x20M 3475          wwohl   87u  IPv4 0x7b77578d546f48c1      0t0    UDP localhost:57900
Plex\x20M 3475          wwohl   88u  IPv4 0x7b77578d502d4889      0t0    TCP *:* (CLOSED)
Plex\x20M 3475          wwohl   90u  IPv4 0x7b77578d546f46d9      0t0    UDP bills-mac-mini:59214
Plex\x20M 3475          wwohl   91u  IPv4 0x7b77578d60d8b121      0t0    UDP bills-mac-mini:53790
Plex\x20M 3475          wwohl   94u  IPv4 0x7b77578d4d7ec889      0t0    TCP localhost:32400->localhost:54800 (ESTABLISHED)
Plex\x20S 3476          wwohl   10u  IPv4 0x7b77578d4f3d4889      0t0    TCP *:49975 (LISTEN)
Plex\x20D 3477          wwohl   15u  IPv4 0x7b77578d4cdf7671      0t0    UDP *:1900
Plex\x20D 3477          wwohl   18u  IPv4 0x7b77578d530db0a1      0t0    TCP *:1990 (LISTEN)
Plex\x20D 3477          wwohl   21u  IPv4 0x7b77578d4c8c05b1      0t0    UDP *:10395
Plex\x20D 3477          wwohl   24u  IPv4 0x7b77578d4bb06859      0t0    UDP *:4992
Plex\x20D 3477          wwohl   27u  IPv4 0x7b77578d530540a1      0t0    TCP *:32469 (LISTEN)
Plex\x20D 3477          wwohl   30u  IPv4 0x7b77578d4bb071e1      0t0    UDP *:54060
Plex\x20D 3477          wwohl   33u  IPv4 0x7b77578d4bb05ce9      0t0    UDP *:49268
Plex\x20D 3477          wwohl   69u  IPv4 0x7b77578d537700a1      0t0    TCP localhost:49976->localhost:49975 (CLOSE_WAIT)
Plex\x20D 3477          wwohl   81u  IPv4 0x7b77578d546f3d51      0t0    UDP bills-mac-mini:52846->router.asus.com:5351
Plex\x20D 3477          wwohl   83u  IPv4 0x7b77578d4d17d4f1      0t0    UDP *:65374
Plex\x20D 3477          wwohl   84u  IPv4 0x7b77578d4d17d121      0t0    UDP *:32414
Plex\x20D 3477          wwohl   85u  IPv4 0x7b77578d532d90a1      0t0    TCP localhost:32400->localhost:49969 (CLOSED)
com.apple 3609          wwohl   14u  IPv4 0x7b77578d5e5fe0a1      0t0    TCP bills-mac-mini:59219->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   16u  IPv4 0x7b77578d5e3910a1      0t0    TCP bills-mac-mini:59263->server-54-230-39-14.jfk1.r.cloudfront.net:80 (ESTABLISHED)
com.apple 3609          wwohl   17u  IPv4 0x7b77578d5e5fe0a1      0t0    TCP bills-mac-mini:59219->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   18u  IPv4 0x7b77578d53054889      0t0    TCP bills-mac-mini:59220->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   19u  IPv4 0x7b77578d546c6889      0t0    TCP bills-mac-mini:59221->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   22u  IPv4 0x7b77578d5217c0a1      0t0    TCP bills-mac-mini:59264->lga15s42-in-f28.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   23u  IPv4 0x7b77578d546c6889      0t0    TCP bills-mac-mini:59221->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   25u  IPv4 0x7b77578d5217c889      0t0    TCP bills-mac-mini:59265->a23-218-138-14.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl   26u  IPv4 0x7b77578d57caa889      0t0    TCP bills-mac-mini:59223->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   27u  IPv4 0x7b77578d531190a1      0t0    TCP bills-mac-mini:59224->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   28u  IPv4 0x7b77578d4ddd10a1      0t0    TCP bills-mac-mini:59222->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   29u  IPv4 0x7b77578d4ddd10a1      0t0    TCP bills-mac-mini:59222->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   30u  IPv4 0x7b77578d53054889      0t0    TCP bills-mac-mini:59220->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   31u  IPv4 0x7b77578d531190a1      0t0    TCP bills-mac-mini:59224->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   32u  IPv4 0x7b77578d5217c889      0t0    TCP bills-mac-mini:59265->a23-218-138-14.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl   33u  IPv4 0x7b77578d5217c0a1      0t0    TCP bills-mac-mini:59264->lga15s42-in-f28.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   34u  IPv4 0x7b77578d53770889      0t0    TCP bills-mac-mini:59225->ord08s12-in-f16.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   35u  IPv4 0x7b77578d532ff0a1      0t0    TCP bills-mac-mini:59226->qa-in-f95.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   36u  IPv4 0x7b77578d532ff0a1      0t0    TCP bills-mac-mini:59226->qa-in-f95.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   37u  IPv4 0x7b77578d58f2b0a1      0t0    TCP bills-mac-mini:59228->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   38u  IPv4 0x7b77578d53770889      0t0    TCP bills-mac-mini:59225->ord08s12-in-f16.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   39u  IPv4 0x7b77578d54dcb889      0t0    TCP bills-mac-mini:59229->server-54-230-38-232.jfk1.r.cloudfront.net:80 (ESTABLISHED)
com.apple 3609          wwohl   40u  IPv4 0x7b77578d57caa889      0t0    TCP bills-mac-mini:59223->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   41u  IPv4 0x7b77578d52236889      0t0    TCP bills-mac-mini:59266->a184-29-106-75.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl   42u  IPv4 0x7b77578d54dcb889      0t0    TCP bills-mac-mini:59229->server-54-230-38-232.jfk1.r.cloudfront.net:80 (ESTABLISHED)
com.apple 3609          wwohl   44u  IPv4 0x7b77578d58f2b0a1      0t0    TCP bills-mac-mini:59228->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   45u  IPv4 0x7b77578d52236889      0t0    TCP bills-mac-mini:59266->a184-29-106-75.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl   46u  IPv4 0x7b77578d4bfea0a1      0t0    TCP bills-mac-mini:59230->lga15s35-in-f31.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   47u  IPv4 0x7b77578d5a86d889      0t0    TCP bills-mac-mini:59231->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   48u  IPv4 0x7b77578d598780a1      0t0    TCP bills-mac-mini:59232->ord08s12-in-f20.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   49u  IPv4 0x7b77578d522360a1      0t0    TCP bills-mac-mini:59267->ec2-50-19-210-136.compute-1.amazonaws.com:80 (ESTABLISHED)
com.apple 3609          wwohl   51u  IPv4 0x7b77578d4bfea0a1      0t0    TCP bills-mac-mini:59230->lga15s35-in-f31.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   52u  IPv4 0x7b77578d61282889      0t0    TCP bills-mac-mini:59233->174.35.76.23:80 (CLOSE_WAIT)
com.apple 3609          wwohl   53u  IPv4 0x7b77578d5a86d889      0t0    TCP bills-mac-mini:59231->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   54u  IPv4 0x7b77578d522360a1      0t0    TCP bills-mac-mini:59267->ec2-50-19-210-136.compute-1.amazonaws.com:80 (ESTABLISHED)
com.apple 3609          wwohl   55u  IPv4 0x7b77578d61282889      0t0    TCP bills-mac-mini:59233->174.35.76.23:80 (CLOSE_WAIT)
com.apple 3609          wwohl   56u  IPv4 0x7b77578d5231e889      0t0    TCP bills-mac-mini:59268->199.16.172.111:80 (CLOSE_WAIT)
com.apple 3609          wwohl   57u  IPv4 0x7b77578d54509889      0t0    TCP bills-mac-mini:59234->31.24.80.23:80 (CLOSE_WAIT)
com.apple 3609          wwohl   58u  IPv4 0x7b77578d5e851889      0t0    TCP bills-mac-mini:59235->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   59u  IPv4 0x7b77578d598780a1      0t0    TCP bills-mac-mini:59232->ord08s12-in-f20.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   60u  IPv4 0x7b77578d5e851889      0t0    TCP bills-mac-mini:59235->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   62u  IPv4 0x7b77578d54509889      0t0    TCP bills-mac-mini:59234->31.24.80.23:80 (CLOSE_WAIT)
com.apple 3609          wwohl   63u  IPv4 0x7b77578d532fa0a1      0t0    TCP bills-mac-mini:59236->ec2-23-21-95-178.compute-1.amazonaws.com:80 (ESTABLISHED)
com.apple 3609          wwohl   64u  IPv4 0x7b77578d613d00a1      0t0    TCP bills-mac-mini:59237->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   65u  IPv4 0x7b77578d5231e889      0t0    TCP bills-mac-mini:59268->199.16.172.111:80 (CLOSE_WAIT)
com.apple 3609          wwohl   66u  IPv4 0x7b77578d613d00a1      0t0    TCP bills-mac-mini:59237->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   67u  IPv4 0x7b77578d5231e0a1      0t0    TCP bills-mac-mini:59269->ec2-107-20-212-170.compute-1.amazonaws.com:80 (ESTABLISHED)
com.apple 3609          wwohl   68u  IPv4 0x7b77578d532fa0a1      0t0    TCP bills-mac-mini:59236->ec2-23-21-95-178.compute-1.amazonaws.com:80 (ESTABLISHED)
com.apple 3609          wwohl   69u  IPv4 0x7b77578d5e6eb889      0t0    TCP bills-mac-mini:59238->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   70u  IPv4 0x7b77578d613290a1      0t0    TCP bills-mac-mini:59259->presentation-atl1.turn.com:80 (CLOSE_WAIT)
com.apple 3609          wwohl   72u  IPv4 0x7b77578d5231e0a1      0t0    TCP bills-mac-mini:59269->ec2-107-20-212-170.compute-1.amazonaws.com:80 (ESTABLISHED)
com.apple 3609          wwohl   73u  IPv4 0x7b77578d6130a889      0t0    TCP bills-mac-mini:59239->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   74u  IPv4 0x7b77578d4d3710a1      0t0    TCP bills-mac-mini:59241->s3-1-w.amazonaws.com:80 (ESTABLISHED)
com.apple 3609          wwohl   75u  IPv4 0x7b77578d51f020a1      0t0    TCP bills-mac-mini:59245->s3-1.amazonaws.com:443 (CLOSE_WAIT)
com.apple 3609          wwohl   76u  IPv4 0x7b77578d5e6eb889      0t0    TCP bills-mac-mini:59238->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   77u  IPv4 0x7b77578d52345889      0t0    TCP bills-mac-mini:59270->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   78u  IPv4 0x7b77578d6130a889      0t0    TCP bills-mac-mini:59239->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   80u  IPv4 0x7b77578d589cd889      0t0    TCP bills-mac-mini:59242->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   82u  IPv4 0x7b77578d589cd889      0t0    TCP bills-mac-mini:59242->lga15s42-in-f25.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl   83u  IPv4 0x7b77578d52345889      0t0    TCP bills-mac-mini:59270->104.28.3.109:80 (ESTABLISHED)
com.apple 3609          wwohl   84u  IPv4 0x7b77578d4d3710a1      0t0    TCP bills-mac-mini:59241->s3-1-w.amazonaws.com:80 (ESTABLISHED)
com.apple 3609          wwohl   86u  IPv4 0x7b77578d532d9889      0t0    TCP bills-mac-mini:59244->ec2-107-21-238-224.compute-1.amazonaws.com:443 (ESTABLISHED)
com.apple 3609          wwohl   88u  IPv4 0x7b77578d4f3d40a1      0t0    TCP bills-mac-mini:59257->server-54-230-39-14.jfk1.r.cloudfront.net:80 (ESTABLISHED)
com.apple 3609          wwohl   89u  IPv4 0x7b77578d532d9889      0t0    TCP bills-mac-mini:59244->ec2-107-21-238-224.compute-1.amazonaws.com:443 (ESTABLISHED)
com.apple 3609          wwohl   90u  IPv4 0x7b77578d59d910a1      0t0    TCP bills-mac-mini:59251->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl   91u  IPv4 0x7b77578d51f020a1      0t0    TCP bills-mac-mini:59245->s3-1.amazonaws.com:443 (CLOSE_WAIT)
com.apple 3609          wwohl  101u  IPv4 0x7b77578d4f25f889      0t0    TCP bills-mac-mini:59247->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  102u  IPv4 0x7b77578d4d7ec0a1      0t0    TCP bills-mac-mini:59249->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  103u  IPv4 0x7b77578d51bfb0a1      0t0    TCP bills-mac-mini:59248->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  104u  IPv4 0x7b77578d50cae0a1      0t0    TCP bills-mac-mini:59250->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  105u  IPv4 0x7b77578d59d910a1      0t0    TCP bills-mac-mini:59251->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  106u  IPv4 0x7b77578d613d7889      0t0    TCP bills-mac-mini:59252->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  107u  IPv4 0x7b77578d51bfb0a1      0t0    TCP bills-mac-mini:59248->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  110u  IPv4 0x7b77578d613d7889      0t0    TCP bills-mac-mini:59252->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  111u  IPv4 0x7b77578d4f52d0a1      0t0    TCP bills-mac-mini:59253->a184-29-105-32.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  112u  IPv4 0x7b77578d4d7ec0a1      0t0    TCP bills-mac-mini:59249->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  113u  IPv4 0x7b77578d612ef889      0t0    TCP bills-mac-mini:59256->lga15s45-in-f28.1e100.net:80 (ESTABLISHED)
com.apple 3609          wwohl  114u  IPv4 0x7b77578d4f25f889      0t0    TCP bills-mac-mini:59247->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  115u  IPv4 0x7b77578d4f52d0a1      0t0    TCP bills-mac-mini:59253->a184-29-105-32.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  116u  IPv4 0x7b77578d50cae0a1      0t0    TCP bills-mac-mini:59250->a184-29-106-91.deploy.static.akamaitechnologies.com:80 (ESTABLISHED)
com.apple 3609          wwohl  117u  IPv4 0x7b77578d4d8830a1      0t0    TCP bills-mac-mini:59258->ec2-54-225-113-36.compute-1.amazonaws.com:443 (ESTABLISHED)
com.apple 3609          wwohl  118u  IPv4 0x7b77578d5d4a88
i was able to stop a process in activity monitor called mDNSresponder and then rebooted the computer. After that, I was able to successfully complete the setup via terminal with plexconnect.  Horray! (sorry for the post after all)
Everything but channels are working on the ATV3. Channels either gives me an error that it cannot load content when I select a video. Or, it errors that "Trailers" are unavailable while trying to view channels plex content.
All of my native media from the computer seems to be working
Any idea on the channels? They are working on my phone and desktop
In the PlexConnect log, it states that the DNS server can not be started since port 53 is already in use…
Your lsof readout confirms this…
Whatever python script is running a dns server on your mac needs to be stopped to run PlexConnect… If the python script that is running port 53 is PlexConnect than you may be trying to run PlexConnect twice and the second instance is throwing that error. Restart your computer, run lsof again and verify that port 53 is not in use.
In the PlexConnect log, it states that the DNS server can not be started since port 53 is already in use...
Your lsof readout confirms this...
Whatever python script is running a dns server on your mac needs to be stopped to run PlexConnect... If the python script that is running port 53 is PlexConnect than you may be trying to run PlexConnect twice and the second instance is throwing that error. Restart your computer, run lsof again and verify that port 53 is not in use.
Thanks for the reply. It seems like its working fine now. I have access to my media from plex on the ATV. What I can't do is access "channels" content from plex.
All functions on the ATV are still working as well.
Which “channel(s)” do not work?
Which "channel(s)" do not work?
Ive tried using CBS, ABC, South Park, Comedy central etc. None are working on the ATV. All work on Mac and iphone.
Im able to see the channels in the ATV, able to navigate their content, seasons and episodes. But once I click on an episode and hit play, i get the error: An error occurred loading this content. Try again later.
My iphone and mac have no issues with the channels. I can even start an episode of something on my phone and airplay it to the ATV perfectly. But Im not able to access them directly through the ATV
Thanks for your help
-> https://forums.plex.tv/topic/119464-plex-media-server-does-not-recognize-version-4-of-plexconnect-real-rtmp-issue/ ?
