On my server, I have a couple HDHR Primes, and an HDHR Connect. Through Emby and NextPVR, I can use both the Primes and Connect in 1 DVR solution. It seems to be an either-or value prop with plex.
Is there a way to run the connects and primes on Plex at the same time? (Or alternatively run 2 plex servers on one machine to have one setup with the Prime and one with the Connect?)
Thanks!
Yes, I have a Prime and a Quatro. I added the Prime first, set it up for my cable channels and let it scan. Then I added the Quatro. It asked me to map the OTA channels to the equivalent Cable channel. For example here in Atlanta, 2.1 ABC = 803 Comcast. But, I cannot control the order of the tuners. I always uses the Quatro first if it’s an OTA channel. Which is what I want, just lucky. But, it would be better that each recording could be setup to choose the tuner as an option.
Ah OK, that seems to make sense. Might cause some issues at the margins if the Prime is used for OTA, but I think I can handle that, will try that setup.
