Live TV/DVR with HDHomeRun Prime and HDHomeRun Connect - Setup
Just a recommendation/Question:
Plex should consider allowing OTA and Cable Card tuners to work at the same time.
I set my Live TV/DVR with my HDHomeRun Prime (Cable), but I can’t get the channel guides to work with my HDHomeRun Connect OTA tuners when the Cable guide. Seems like this should be an easy fix for multiple tuners.
It’s either Cable tuner or OTA tuner, but not both at the same time.
Question:
Plex allowing OTA and Cable Card tuners to work at the same time.
is it possible to Live TV/DVR with my HDHomeRun Prime (Cable) and my HDHomeRun Connect OTA tuners work together,
will I get channel guides for Cable guide and OTA tuners.
This is an issue I wish would get fixed soon. Please vote for this feature request with Plex at
Multiple epg sources, for those with multiple tuners.
