I apologize for not getting back to you sooner. Can you tell me whether you’re on a NAS or PC for your music library? And whether it’s a MAC or PC if it’s a computer?
Thanks.
I’m using a Synology NAS DSM 7.1 with the Plex beta app. I use JRiver and can export my playlists in a number of formats or if there is a way to since them like we do for music. I would like the pdf as well please. cowilliams at msn com
Thank you!
I don’t use JRiver so I can’t speak to how my document might work for you. This document is meant to get iTunes playlists to import into Plex.
As covered in the document, I have a full-version of Plex so it may limit you from successfully getting this to work - but I can’t say for sure as I was only working with the full license version.
As you’re looking to export your playlists from JRiver and get them into Plex, I’m not sure if this would be the right document for you. Do you know if JRiver playlists are in the XML file format?
Thank you! I can convert them if I need to. I can send them to iTunes so I should be able to make this work. I will take a look. I have the full version as well. Just using the beta version for Synology NAS.
I would appreciate seeing your doc - my email address is lgniceguy@gmail.com. I’m using Plex on a Synology NAS. I see in the notes in this thread about “click the 3 dots next to playlists”, however on my Plex server this only shows me Unpin , and no import option.
I’ve sent a copy to your email address. Let me know you received it please. Thanks!
@bubbascant Can you please post your document to Google Docs or something to share it out? I’d love to go through it, but I’m not a fan of posting e-mail addresses to public forums. Thanks!
Just to add for Plex support seeing this, clearly it’s an issue alot are seeing:
https://www.reddit.com/r/PleX/comments/rydmco/something_went_wrong_make_sure_the_server_is/
https://www.reddit.com/r/PleX/comments/n7yx05/plex_import_itunes_playlist/
Has anyone tried and had luck getting this to run?
My apologies for my late reply. I was out of town for a number of days. Can you please send me your email address and I’ll get the document off to you.
Hi
Can you email me the document for configuring Itunes Playlist please. junkermailme@gmail.com
Are you using a desktop computer or a NAS?
I’m using a Windows 10 Desktop.
Windows 10 desktop.
I like knowing who is viewing my file, and be able to follow up with them. You could create a temporary email in gmail for example, provide it and then delete it once you receive it from me.
Cheers!
