Don't use Local Media Assets
Server Version#: 1.20.1.3252
Hi all,
I just upgraded to the new plex movie agent. I made a complete metadata refresh and noticed that local posters and artwork are now used as default. I noticed that also my music library is preffering local media assets.
From the documentation I found this:
“The new Plex agent gives you the option to use local image assets independently from any embedded metadata. Setting the Use local assets preference will pick up any local image assets and use those over the ones pulled from the cloud.”
My question: There can I find the Use local assets option? I tried the settings from new plex movie agent but there are no options. I would like to change for movies and music that online metadata are preferred to local media assets.
Thanks for any help!
Edit the library and go to Advanced:
