Downloaded Files
I’m new to forums so I don’t even know if I’m posting in the right area. Can someone tell me where Plex downloads files to in macOS Big Sur 11.1? I used to be able to able to fine them but now I can’t the folder at all. Any help is appreciated.
Are you asking where Plex Media Server stores its data? If so, open Finder, select Go -> Go to Folder in the menu, and then enter the path: ~/Library/Application Support/Plex Media Server.
And if you’re asking where the Plex for Mac player stores downloaded videos…
~/Library/Application Support/Plex/Plex Media Server/Sync/
Found it! Thanks all!
