Downloading Episode Titles - Why it doesn't occur
I have TV shows names such-as this:
/ Bob’s Burgers / Season 1 / Bob’s Burgers - s01e01.mp4
Yet when I do a scan of the folder, it tends to title the episode by it’s Metadata; “Bobs Burgers - Season 1 - Disc 1”
Is there a configuration setting I’m missing so that when it scans the folder and gets the episode information (of which the summary and episode air date, etc. is updated), it also updates the title of episode automatically as well?
Thanks…
Yes:
Go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
Settings - Server - Agents - Shows - TheMovieDatabase
Settings - Server - Agents - Movies - Plex Movie
Settings - Server - Agents - Movies - TheMovieDatabase
Afterwards, Refresh Metadata.
Great! Thank you very much; that worked as you suggested.
