Downloads not working for transcoded files
Server Version#: 1.24.5.5173
Player Version#: 7.24.1
I had to delete and reinstall the iOS client to get downloads to work at all (sync has always worked fine), however I seem to have a glitch for some files that froze when the iPad locked that needed transcoding.
I’ve deleted those files from the download queue and kicked them off again, but they never seem to download.
The Download section shows the downward arrow, and the server status shows it’s transcoding the file, but then the downward arrow in the mobile client disappears completely (while the file is still transcoding), and never reappears.
Once the server says transcoding has finished, the server status goes back to nothing in progress, but nothing downloads. The mobile client says there is a download in progress from the downloads menu, but no progress indicator or any apparent activity against the file itself.
I don’t want to reinstall the app again, as I’ve had to download 11 files already, and don’t want to start again.
Anyone have any ideas on how to check the download status, make it reappear of give it a kick to make sure the download is happening when the transcode has finished?
Sync was so much more reliable than Downloads :frowning:
Hard reboot of the iPad seems to have fixed it
And back to not working :frowning: Transcode finishes, download doesn’t start. Tried restarting the app, rebooting the iPad, and downloads aren’t working.
Any ideas?
Plex Media Server Logs_2021-11-28_10-44-11.zip (7.0 MB)
PlexDebugInfo-Synn-7.25-1615 (2021-11-28 10.44.34 +0000).zip (3.7 MB)
Client and Server Logs attached
Looks like your server logs didn’t get uploaded properly. Can you reproduce and get me a new set of logs?
Plex Media Server Logs_2021-12-10_09-47-57.zip (6.3 MB)
Here’s new server logs
PlexDebugInfo-Synn-7.26-1822 (2021-12-10 09.49.46 +0000).zip (2.9 MB)
And client logs too
Your logs indicate the app is having trouble finding the things you’ve downloaded. I posted this summary of known issues. Update on new Downloads feature
I think this might be issue 1.
The download doesn’t show as complete though. The server status gets to the end of transcode and the client says downloading but the status wheel disappears.
I did manage to download some other files previously after I completely deleted the app from my iPad but I now have about 13 films downloaded and don’t really want to do that all again. It hasn’t worked since.
I’ve tried a number of different files and they all do the same at the minute
If it is number one then there’s no workaround - does that mean the sync function will remain until fixed? Otherwise I have no way of storing offline content
Are these movies or TV shows? If it a show, look at issue 3.
All movies
Can you get me the xml info for the movie “No Time to Dies”? That is the last movie I see you trying to download. PMS shows it did transcode the file and I do not see it downloading into the iPad.
ntt.zip (12.6 KB)
Here it is. Thanks
Looks like it might be issue 4. I’ve just changed my DNS to 1.1.1.1 on my iPad, forced close Plex and restarted and the download kicked off.
Not sure why it stopped working as all the other downloads that successfully completed a few weeks ago were using internal DNS on my network.
Will try another film when this has downloaded
Changing DNS seems to have fixed it. Now downloaded 3 new movies without issue….
