Hey,
I turned on the new experimental Download feature and I downloaded 3 episodes from a single show. The download process was fast and worked fine. However, when I try to play something from the Download tab, the app just restarts. I tried this multiple times with the same outcome. If I play the show from the Home tab (keep watching or on deck list), the episode starts playing fine but I assume it’s not using the downloaded media because if I skip to a different scenes, it always takes some time to laod and that shouldn’t happen if the file was downloaded in my device.
Manufacturer: OnePlus
Device: OnePlus5
Model: ONEPLUS A5000
Product: OnePlus5
Version: 10
Server Version: 4.59.2
Player Version: 8.19.1.26306
I attached logs from Android client.
Thanks,
Carlos
plex-log-cmiguel97.zip (1.3 MB)
