"Downloads on Cellular" & "Prefer Downloaded Media" settings not respected
Hi there,
I love Plex and Plexamp, I moved away from iTunes and WinAmp recently to express my new faith :slight_smile:
Now I have a problem with PlexAmp in iOS; maybe similar to another post I saw on Android. See below, reproducable and tested many times.
iOS 13.5
Plexamp 3.1.0
Multiple playlists downloaded over WiFi (total 1501 tracks)
Settings / Downloads
Quality : automatic
Downloads on Cellular : OFF
Prefer Downloaded Media : ALWAYS
I switched off my WiFi and only connect over 4G.
I specifically search a song which I know is part of my downloaded playlists. When I play it, it is downloaded over 4G and I see the progress bar as it starts to play.
Unless I do not understand the settings, I believe there is something wrong.
Thank you
When did you download those playlists? If they were before v3.1 (IIRC), you’ll need to re-download, otherwise they are missing a bit of data needed to use them for that purpose.
Good point.
I will do a Refresh of the Downloads.
And just to be super pedantic “Refresh All” won’t do it, you’ll need to delete and then recreate the downloads (sorry)
Many thanks. This is working as designed now.
“Long live plexamp !”
