https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Season-Based-TV-Shows
http://thetvdb.com/?tab=series&id=76107&lid=7 - Doctor Whoâs First Run Seasons will need (1963) due to an epic blunder by Plex. A blunder theyâre refusing to do anything about.
Having said that, the ONLY way to get anything regarding reliability with TV Shows in Plex is to follow the guidelines for naming and structuring to the letter. There is no wiggle room. In order for shows to match with TVDB (Plexâs ONLY TV Show Database) they MUST be in a particular structure with particular file naming or it simply wonât work.
TVDB and Plex REQUIRE this:
A TV Show Library/
âŠDoctor Who (1963)/
âŠSeason 01/
âŠDoctor Who (1963) - S01E01 - An Unearthly Child (1).xxx
âŠDoctor Who (1963) - S01E02 - The Cave of Skulls (2).xxx
âŠDoctor Who (1963) - S01E03 - The Forest of Fear (3).xxx
âŠDoctor Who (1963) - S01E04 - The Firemaker (4).xxx
and so on - exactly the way TVDB lists them - shown in the TVDB link above.
You donât need the episode name in the file name, but you at least need this much of the name to match the guideline:
âŠDoctor Who (1963) - S01E01.xxx <â perfectly valid file name for Season 1 Episode 1.
You also (so Iâm told) donât need (1963) In the file name, but my personal OCD wonât allow me to fix the Show Folder and not fix the file names. You WILL AT LEAST need (1963) in the Show Folder as shown above or it simply wonât work.
If you happen to have, or can create, single files consisting of a complete story arc, youâll have to name them like this:
A TV Show Library/
âŠSeason 01/
âŠDoctor Who (1963) - S01E01 - Whatever this Arc is Called [Parts 1-4].xxx
âŠDoctor Who (1963) - S01E04 - The Daleks [Parts 1-7].xxx
âŠDoctor Who (1963) - S01E12 - Whatever this Arc is Called [Parts 1-2].xxx
and so onâŠ
then hand edit in the details, if necessary.
Things that make your file name Non-Compliant must be put in [Brackets] so Plex will ignore that bit, or it wonât work.
You can also fiddle around with the method the first poster came up with, but as soon as you realize how badly Plex mishandles âStacked TV Show Episodesâ youâll probably abandon that âWork-Aroundâ entirely.
I already know this isnât going to make die-hard Doctor Who fans very happy. TVDB isnât concerned about your happiness and neither is Plex for that matter, but if you want these things to match and be populated with material thatâs what you have to do.
If you just canât deal with it, create a TV Show Library with Personal Media Shows as itâs main Agent (in Advanced Settings while creating the Library) and Plex wonât even try to match any of them. You can name and structure them how you want to and hand edit every single episode so itâs does exactly what you want it to.
Alternately you can create an âOther Videosâ Library and do the same thing. This library type is really hard to deal with when TV Show Type Structures are employed, will take a good bit of fiddling and it remains to be seen if youâll ever come away with anything close to what youâre looking for.
PITA? You Betcha! (when you get about 200 episodes into this job - youâll realize just how big a PITA it is, Iâll wager)
Unfortunately those are your options.
